Kamoj Kamoj add-on V5 for Netgear R7800 X4S and R9000 X10
@kamoj: Thanks for your reply. In the meantime I've found the solution for the login popup error on the openvpn setting page: a password change for the web interface. After changing the password, the opevpn and the routerinfo pages work without problem.
I experienced the same issue with the unsatisfied user/pass dialog when accessing the OpenVPN Client tab on Chrome 79.0.3945.86. Thank you for posting your solution, resetting the web password (Advanced>Admin>Set Password) worked for me, too.
I'm sorry I had no time to write instructions or help.
Voxel encouraged me to release this in a rush before xmas.
Without him there would be no addon!
Find the section: Create OpenVPN Client Configuration
  • Fill in your Credentials: User Identity/Name and Password
  • Select your "OpenVPN Provider" in the drop list .
  • Wait for some time...
    ... for measuring speed of all servers.
  • Make your choice(s) and select a server in the drop list.
  • "Create configuration"
  • "Start VPN with this".
(I recommend that you check "Cyclic Status update" at top of page,
and check the log file.)
If windscribe allow free access to .ovpn files no problem to add support. Do they?
Ad- and malware etc blocking :
I have no opinion,
We all in community have to help!
This might sound like a dumb question, but can someone explain how to use the openvpn part?
Also which is the recommended adblock service everyone is using?
Finally, in the next update, whenever that is, would it be possible to add windscribe?
Thanks [emoji1417]
Sent from my GM1903 using Tapatalk
why does add on says a version which doesnt released yet
Shh... Silent release... No new threads. For R9000 and Orbi too... Happy New Year!
Voxel.
is Kamoj add-on compatible sir with new release? if it's included what commands are needed to be ran through telnet? happy new year Master.
Thanks for the new release. See you next year! ;)
Hi Kamoj!
Many thanks for this :)
One small issue I've found on this router whilst using an OpenVPN client: NAT loopback/hairpinning doesn't work. Meaning that if I have the OpenVPN client connected, I can't connect to my WAN IP and access internal services through the NAT port forwarding. This is possible while I'm not using the OpenVPN client. It does not matter whether the client is in the bypass list or not, in both cases it stays trying to connect and times out eventually.
Keep in mind this is not specific to your setup - I get the same behaviour using this: https://www.myopenrouter.com/article/how-set-openvpn-client-netgear-r7800-voxels-custom-firmware
But maybe you or Voxel have some idea on how to fix it. It feels to me that we probably need another `ip rule` to push our connections through the right interface.
The reason why this is useful is that I have a domain name pointing to my WAN IP so I can access some services I have at home. These work when I'm outside of my home connection, but not when I'm at home if I'm using the VPN, and I have to use direct internal connections (which is a pain as the port is not the same).
When I am trung to download the addon to my router it says voxel-firmware.com is unresoavable. My router isn't connected to the internet as I would like to use this addon to enable option 61 for me to be able to connect. Is there a way to transfer the file across or another way?
Thanks!
Thanks!
Download the file to your computer and copy it to a USB stick. Insert the stick in the router's USB port and copy from /mnt/sda1 to /root (for example); cp -f /mnt/sda1/*.ipk /root
Then: /bin/opkg install --force-overwrite /root/*.ipk
fwiw: if you load it onto a usb stick you can install it directly from the usb stick, no copy into the router necessary
Great job, Kamoj.
Hello guys, was someone able to tune and get correct setting for the add blocking part? I'm using adaway for now only but I would like to know if there is something more specific for youtube adds and android apps. Thank you
Inviato dal mio Mi 9T Pro utilizzando Tapatalk
Sorry for the noob question, but how do you download the file directly onto your computer or your USB stick ?
