Kamoj Kamoj add-on V5 for Netgear R7800 X4S and R9000 X10
The 5.1 beta is being tested at the moment.
I suggest you use the 5.0 beta until 5.1 is released.
The known 5.0 beta bugs are listed in the #2 posting in this thread.
If there is some new feature from 5.1 beta you need, please let me know!
kamoj, is it safe to use your new 5.1 even for a little noob like me? i'd like to try
i'd like to use wifi guest bandwidth limit feature, telnet activated on boot and a strong adblock.
Thank You
Kamoj add-on 5.0 already support "strong adblock".
Kamoj add-on 5.1 do support "telnet activated on boot".
Kamoj add-on 5.1 doesn't support "bandwidth limit features". Thank you for showing the interest in such a function!
So there is little reason for you to currently not use the public 5.0 beta.
Thank You
Open VPN setup works like a charm (PrivateVPN). Be sure to download the .ovpn server list from the PrivateVPN site and unzip in /etc/openvpn/config/client/ (dir TCP and UDP must reside there containing the .ovpn files).
Those will be recognized in the config screen for OpenVPN, select, enter your credentials and run. Excellent! Many thnks!!!!!!!!!
Good you like it.:)
But even better: You don't need to download any server list/files manually since the add-on supports PrivateVPN!
Just chose PrivateVPN in "Create OpenVPN Client Configuration" etc.
(wait 20 seconds or so for servers to answer, select "Country", "Server", "Create Configuration", "Start VPN with this").
Hope you can try that too and report if it's working!
Good you like it.:)
Hope you can try that to and report if it's working!
Confirmed!
On several pages of the add-on I received prompts for user name and password and when I enter my credentials they are not accepted. Other users have reported this in the past and suggested changing the password. In the process of playing with passwords, I noticed that the add-on does not like passwords with dollar ($) signs. Can this be fixed?
If you mean passwords for OpenVPN, its fixed in the Beta version. Many things are better in next release.
https://www.snbforums.com/threads/k...ar-r7800-x4s-and-r9000-x10.60590/#post-532396
OpenVPN Client: Create OpenVPN Client Configuration: Fixed credential containing blanks and special characters
The OpenVPN page was one where the credentials window popped up. But is also appeared when I clicked the 10 s refresh check box on the status page. Have you tried using a router password with a $ sign in it?
Those passwords are pure Netgear/Voxel. The add-on has nothing to do with the router password at all.
So avoid using the refresh check box - if that helps.
I never had this problem myself, so I can not help you with this.
But its a good information that it might happen with "$" in the router password.
There is quite a mess in the Netgear code regarding "special characters", its on my todo list to clean it up...
It may well be that the issue is with the netgear code and just manifests itself when using the add-on. I will take that advice for now and see if anything changes with the next version of the add-on.
Hello,
Looking for guidance with setting up openvpn using ExpressVPN on a R9000 running Version (Voxel) V1.0.4.39.1HF firmware. I had been using Kong’s last DDWT which began being a bit troublesome lately. Followed the process to transition back to the latest Netgear firmware successfully. Next installed Voxel V1.0.4.39.1HF firmware, followed the first semiautomatic install method of OpenVpn using a USB stick. At this point the router has internet connectivity and OpenVPN client fails to start. I opted to install the Kamoj add-on V5 to take take advantage of the many enhancement it makes available. This add-on is fantastic! The error log is consistent with the “Client:Error: OpenVPN client start failed. No process or tun21 found”. I am completely stuck here. Got past some of the nuances V5 of the add-on brought with using authentication file. Below is the log section for last attempt to get the client working and further information on the network setup.
Main Router is a Cisco RV345
  • Currently have UNPN enabled
  • Disable firewall to test if it was causing the problem…erorred with same notice
  • Port 1195 UDP & TCP forwarding to 172.16.9.1
Netgear R9000 is a VPN Only router
  • DNS is set to ExpressVPN’s recommendation
    • 8.8.8.8
    • 8.8.4.4
    • 156.154.70.1
  • Mode is Router
  • Router has DHCP enabled.
  • Only MacBook connected to router with WIFI and an Ethernet slot
  • SSH enabled and working with key pairs.
  • Kamoj add-on V5 installed
Session Log Section
2020-04-15 15:08:19 [OpenVPN] Client:Existing OpenVPN nvram configuration found: expressvpnDenver.ovpn
2020-04-15 15:08:19 [OpenVPN] Client:Check if DNS is already working
2020-04-15 15:08:19 [OpenVPN] Client password file given and exist.
2020-04-15 15:08:19 [OpenVPN] Client:Copy /etc/openvpn/config/client/expressvpnDenver.ovpn and change dev to: tun21
2020-04-15 15:08:19 [OpenVPN] Client:******* ip route before START:
default via 172.16.8.1 dev brwan
172.16.8.0/24 dev brwan proto kernel scope link src 172.16.8.2
172.16.9.0/24 dev br0 proto kernel scope link src 172.16.9.1
239.0.0.0/8 dev br0 scope link
2020-04-15 15:08:19 [OpenVPN] Client:Starting OpenVPN client expressvpnDenver.ovpn, device: tun21. Please wait...
Wed Apr 15 15:08:19 2020 WARNING: --keysize is DEPRECATED and will be removed in OpenVPN 2.6
Wed Apr 15 15:08:19 2020 OpenVPN 2.4.8 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Wed Apr 15 15:08:19 2020 library versions: OpenSSL 1.1.1e 17 Mar 2020, LZO 2.10
Wed Apr 15 15:08:19 2020 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Wed Apr 15 15:08:19 2020 Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Wed Apr 15 15:08:19 2020 Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Wed Apr 15 15:08:20 2020 nice -20 succeeded
Wed Apr 15 15:08:20 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]70.39.102.170:1195
Wed Apr 15 15:08:20 2020 Socket Buffers: R=[212992->425984] S=[212992->425984]
Wed Apr 15 15:08:20 2020 UDP link local: (not bound)
Wed Apr 15 15:08:20 2020 UDP link remote: [AF_INET]70.39.102.170:1195
Wed Apr 15 15:08:20 2020 TLS: Initial packet from [AF_INET]70.39.102.170:1195, sid=549c09f2 03891a11
2020-04-15 15:08:41 [OpenVPN] Client:INFO: OpenVPN client pid:6138/PID:6138 started with: /usr/sbin/openvpn--devtun21--fast-io--nice-20--auth-nocache--sndbuf786432--rcvbuf786432--tun-mtu1500--mssfix1460--txqueuelen1000--writepid/var/run/openvpn-client.pid--cd/etc/openvpn/config/client--log-append/var/log/openvpn-client.log--config/tmp/openvpn_conf/expressvpnDenver.ovpn--script-security2--up/etc/openvpn/ovpnclient-up.sh--down/etc/openvpn/ovpnclient-down.sh--daemon--pushsndbuf 786432--pushrcvbuf 786432
2020-04-15 15:08:41 [OpenVPN] Client:Error: OpenVPN client start failed. No process or tun21 found
2020-04-15 15:08:41 [OpenVPN] Client:Connection is DOWN:
Wed Apr 15 15:08:41 2020 event_wait : Interrupted system call (code=4)
Wed Apr 15 15:08:41 2020 SIGTERM[hard,] received, process exiting
2020-04-15 15:08:41 [OpenVPN] Client:Optimize Stop. Turning Turbo mode off
2020-04-15 15:08:41 [OpenVPN] Client:Stopped. Restarting Firewall
2020-04-15 15:08:41 [OpenVPN] Client:Remove bad entry from ip route after stop: ip route del:
2020-04-15 15:08:41 [OpenVPN] Client:[OpenVPN] Client:******* ip route before STOP:
2020-04-15 15:08:41 [OpenVPN] Client:******* ip route after STOP:
2020-04-15 15:08:41 [OpenVPN] Client:Stop completed
Full VPN Log Section
Looking forward to using the firmware and add-ons. Looks like huge amount of great work putting this together!
Welcome to this community @walleyez !
Apparently ExpressVPN does not "create" the vpn tunnel as it should.
Have you used the Kamoj add-on to create the .ovpn file?
And how is user/password entered?
It's good if you can PM me your .ovpn file contents.
Sorry to say I have not been able to give "native" support to ExpressVPN even if it might be one of the very best in many ways.
This is because they don't publish their .ovpn files, and maybe they even are specific for each user, like Mullvad and others.
So if you trust me contact me via PM and will try to help you of course.
Sincerely,
Kamoj
Kamoj
Man thank you very much for the quick response! I did end up using your add-on to create / rename the the auth.txt file. Found a post from you back on Dec 29th that laid out the work around to get past the "No password file found". User and password are stored together in a .auth file separate from the .ovpn file.
I'd be more than happy to send you the ovpn file. I several different ovpn files that are downloaded from the ExpressVPN site. They actually have a DDWRT setup guide along with ovpn files for each different server location. Depending on you router / setup you may use the whole thing or cut pieces out of it with their instruction.
That being said I can't find how to send you a PM...I just became member on her today to send my previous message. Think I've been up a bit too long fighting with this router. Is it the start a conversation link that is in your profile?
  • Like
Reactions: KW.
Kamoj
Same thing happened to me when I updated one of the 5.1 beta addons (8.6 to 8.7). Suddenly the VPN connection that had been working with no problems and the same .ovpn and password files stopped with the log showing the same as walleyez. I uninstalled the update and installed the previous (which was working with the same .ovpn file). It did the same thing. Tried a few different .ovpn files and 1 worked. seemeed ok and then updated the 5.1 beta addon. All OK and has not reoccured with subsequent updates. Only difference between the .ovpn file that worked and the one that stopped was the IP address of the VPN server - same location just a different IP access. Do not know why it happened but has worked OK ever since and with each further beta update! Can send you the VPN log if it helps as I kept a copy in case I needed to raise a query if it did not clear.
Hope that helps
  • Like
Reactions: KW.
Kamoj,
In another message thread you encouraged me to followup on trying to get PureVPN running on your V5 addon. I finally got the chance to try it today (R7800, Voxel 76.1SF, kamoj addon V5, most current (2020) linux PureVPN udp openvpn.opvn file as you suggested) and got a strange result. The script loaded and the VPN indicator in your gui indicated a successful connection. However, I could not access anything on the internet. I've included the log file below and hope you will have an opportunity to see if you can determine where I am going wrong. I also tried the ca2*.ovpn file and got the same result. I do note now that the date is wrong, April 22 rather than 25, but am unsure if this is important and I have restored my internet servise with my EA8500. A intial issue is that when I imported the *.ovpn files in your gui they were saved with an extra space between every line. I had to manually edit the file to remove the spaces as the various certificate blocks don't work with spaces between the lines. As well I tried repeatedly to join the beta testing program for your 5.1 and beyond addon by voting but nothing seemed to result from the voting exercise. I would have tested an updated version if I could have and will do so if I can obtain a copy to test. Even with my minor problem I can see the major benefit of your addon to Voxel's excellent firmware.
Thank you in advance for any assistance!
LSM
2020-04-22 11:29:06 [OpenVPN] Client:Existing OpenVPN nvram configuration found: usny2-ovpn-udp.ovpn
2020-04-22 11:29:06 [OpenVPN] Client:Check if DNS is already working
2020-04-22 11:29:06 [OpenVPN] Client:Password file given and exist.
2020-04-22 11:29:06 [OpenVPN] Client:Copy /etc/openvpn/config/client/usny2-ovpn-udp.ovpn and change dev to: tun21
2020-04-22 11:29:06 [OpenVPN] Client:******* ip route before START:
default via 99.254.68.1 dev brwan
99.254.68.0/23 dev brwan proto kernel scope link src 99.254.69.235
192.168.2.0/24 dev br0 proto kernel scope link src 192.168.2.253
2020-04-22 11:29:06 [OpenVPN] Client:Starting OpenVPN client usny2-ovpn-udp.ovpn, device: tun21. Please wait...
Wed Apr 22 11:29:07 2020 OpenVPN 2.4.9 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Wed Apr 22 11:29:07 2020 library versions: OpenSSL 1.1.1g 21 Apr 2020, LZO 2.10
Wed Apr 22 11:29:07 2020 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Wed Apr 22 11:29:07 2020 nice -20 succeeded
Wed Apr 22 11:29:07 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]172.94.86.4:53
Wed Apr 22 11:29:07 2020 UDP link local: (not bound)
Wed Apr 22 11:29:07 2020 UDP link remote: [AF_INET]172.94.86.4:53
Wed Apr 22 11:29:08 2020 WARNING: 'link-mtu' is used inconsistently, local='link-mtu 1557', remote='link-mtu 1558'
Wed Apr 22 11:29:08 2020 WARNING: 'comp-lzo' is present in remote config but missing in local config, remote='comp-lzo'
Wed Apr 22 11:29:08 2020 [Secure-Server] Peer Connection Initiated with [AF_INET]172.94.86.4:53
Wed Apr 22 11:29:10 2020 TUN/TAP device tun21 opened
Wed Apr 22 11:29:10 2020 /sbin/ifconfig tun21 172.94.86.205 netmask 255.255.255.192 mtu 1500 broadcast 172.94.86.255
Wed Apr 22 11:29:10 2020 /etc/openvpn/ovpnclient-up.sh tun21 1500 1557 172.94.86.205 255.255.255.192 init
/opt/xagent/run-xagent.sh: /opt/xagent/run-xagent.sh: 3: system: not found
/opt/xagent/run-xagent.sh: /opt/xagent/run-xagent.sh: 4: system: not found
Please specify hardware_id (by --hardware_id option) to run xagent.
It should contain only upper latin letters and numbers and have 13 symbols
/opt/xagent/xagent: [-d|--daemon] [-c|--config_file <file name>]
[--disable_console] [--disable_log_file] [--model_id]
[--ca_path <path to CA folder>] [--ca_file <path to cert file>]
[--log_debug|--log_info|--log_warning|--log_error|--log_silent]
[-w|--watchdog] [-v|--version] [--log_file <filename>]
[-s|--service_id <service_id>] [--discovery_time <discovery time>]
[--discovery_id <id>] [--carrier_id <id>] [--discovery_data <data>]
[--start_paused] [--log_file_cnt <count of files in rotation>]
[--log_file_size <max size of log file before rotation in human format: nK|nM where n in 1-9999>]
[--pid_file <pid_file>] [--watchdog_pid_file <pid_file>]
[--broker_keepalive <time>,<probes>,<intv>] [--agent_keepalive <time>,<probes>,<intv>]
[--agent_heartbeat <time>]
--hardware_id <hardware id> [--model_id <model_id>]
2020-04-22 11:29:10 [OpenVPN] Client:INFO: OpenVPN client pid:5191/PID:5191 started with: /usr/sbin/openvpn--devtun21--fast-io--nice-20--auth-nocache--sndbuf786432--rcvbuf786432--tun-mtu1500--mssfix1460--txqueuelen1000--writepid/var/run/openvpn-client.pid--cd/etc/openvpn/config/client--log-append/var/log/openvpn-client.log--config/tmp/openvpn_conf/usny2-ovpn-udp.ovpn--script-security2--up/etc/openvpn/ovpnclient-up.sh--down/etc/openvpn/ovpnclient-down.sh--daemon--pushsndbuf 786432--pushrcvbuf 786432
2020-04-22 11:29:10 [OpenVPN] Client:Connection is UP: tun21 1500 1557 172.94.86.205 255.255.255.192 init
Wed Apr 22 11:29:10 2020 Initialization Sequence Completed
Content-type:text/html
2020-04-22 11:29:10 [OpenVPN] Client:Waiting up to 10 s etc to let password etc fail before checking log-file for connection
2020-04-22 11:29:10 [OpenVPN] Client:INFO: OpenVPN Client started and connected. : usny2-ovpn-udp.ovpn : tun21 : Secure-Server 172.94.86.4:53
2020-04-22 11:29:10 [OpenVPN] Client:Optimize Start. Setting Turbo mode on
2020-04-22 11:29:10 [OpenVPN] Client:Started. Restarting Firewall
2020-04-22 11:29:11 [OpenVPN] Client:Start completed
2020-04-22 11:29:11 [OpenVPN] Client:[OpenVPN] Client:******* ip route after START:
0.0.0.0/1 via 172.94.86.193 dev tun21
default via 172.94.86.193 dev tun21
128.0.0.0/1 via 172.94.86.193 dev tun21
172.94.86.4 via 99.254.68.1 dev brwan
172.94.86.192/26 dev tun21 proto kernel scope link src 172.94.86.205
2020-04-22 11:29:11 [OpenVPN] Client:Waiting again up to 10 s etc to let password etc fail before checking log-file for connection
If you want join beta test program you simply contact me via PM or like you do here, no problem.
The poll is just a voting for the general interest of different router.
About your vpn issue:
I agree the log looks good, but if you have the wrong date it will not work.
I'll send you a PM with link to beta program where you can test the new beta version,
which handles erroneous date.
For now you can follow the instruction in Voxel readme.docx and set up a delay in the openvpn client:
Login to router command line and run these 2 commands, and reboot:
nvram set vpn_client_delay=120
nvram commit
This will cause a 2 minutes delay before starting the openvpn client both att boot time and every time you
switch it on, but it might help your router to get services like ntp and dns to work before the vpn client starts.
Kamoj,
LSM
nvram commit
Kamoj,
your advice was very helpful! I downloaded the 5.2-2beta, installing it as recommended (i.e., first uninstall the previous version). With a bit of fiddling about and redoing the VPN transformation of a PureVPN *.opvn file for Canada (ca2) I got it working. That is the good news. Although PureVPN says the site is in Toronto (I'm north of Toronto) it links to an OpenVPN server in Montreal. With my current router (Linksys EA8500 with most current dd-wrt firmware) and some script tuning from a base down/up connection of about 320/17 Mbps I get OpenVPN performance of 50-70/14-16 Mbps, with a ping of 16-50 ms, depending on the time of day and the test program used.
The bad news is the R7800 at this stage gets, from the same base connect rate and same Montreal server, about 30/16 Mbps with a ping of 50 or more. I tried a New York config file but the performance was even poorer. So, rather than getting about double the EA8500 throughput I'm getting about half, despite the presence of the network accelerator subsystem in the R7800. It may be a few days before I can get back to this. If there is something specific that you might wish to have tested and reported on to help to better understand what is going on and/or some suggestions regardng what "tuning" might be worth while exploring please let me know. Also, if you are interested in the successful R7800 OpenVPN logs and/or the ca2*.opvn file I can forward them to you if you have a recommended way of doing that.
Finally, the 5.2b2-2 addon appears to work well in the relatively short time I spent with it. It sure helps to navigate and extend the firmware GUI!
LSM
