KEEP GETTING HACKED AND ROOTED IN MY RT-86ACU
KILLME32.wxe
I keep getting Hecht I’ve tried everything changing to cable refreshing rebooting multiple times I don’t know what to do anymore look at the logs if someone can explain what’s happening and how I can prevent it would appreciate it I don’t know how they keep getting in the change my router settings in like a virtual environment like in kernel mode in the router
  • syslog 8.txt
First, what model router do you have (it's not a RT-86ACU) and what firmware version are you running?
Your local IP address range is invalid. It is set to 12.10.12.x which is a public range. I suggest you factory reset your router and set it up again to correct this problem and any others.
At 10:25:57 your router lost its connection to your modem. So it looks like this is a problem with your internet connection and/or modem and not the router.
Did u even read the files they changed my admin password activated wireless.. two times fo to the end of log 7 you can see strange account trying to remove settings in my firewall and they they complete acess over the router…
Take your router offline, now.
Go to a friend's and download the latest firmware you want to use on it. Do not use your computer/devices to touch the router at all, until you've scanned them thoroughly for viruses via multiple methods.
Do not connect your router back to the ISP before you have completed the following steps.
Perform a full reset to your router/network set up. Do not use any saved backup config files afterward. Do not use your old passwords. Do create a 16 alphanumeric character password that is not easily guessed (random letters/numbers is ideal) that doesn't have any punctuation, spaces, special characters, or smiley faces.
Flash the downloaded (and verified) firmware to the router and repeat the steps again.
Only connect to your ISP when you have fully cleared and reset the router multiple times, in multiple ways. And with new passwords too.
Fully Reset Router and Network
I I bought a second router just because I knew this was a big problem should I plug it in right now or should I configure it at my friends house
I’m sorry for not being more specific but like it’s just it I thought or assumed that the end of log seven u can see different account spamming settings… And u can kinda see the injection in one log, I have the latest Merlin does this mean there is an exploit for that
Again, whether you are trying to configure the router that got hacked or a brand new one, I wouldn't trust doing so with any computers that were connected to the hacked router (until they're fully scanned/cleaned).
My bad really tired been fighting this back door for weeks now… and when I’m about to win it delete my OS, that’s why i bought a raspberry… and have it connected to another internet source gonna download windows and stuff and make bootable srives from raspberry if that is possible
Nah I got a completely new raspberry that haven’t had no connection with the router and I’ve unplugged the router.. But basically my whole home is hacked I have the windows event logs somewhere ccoudlnt even use hirens it took hire a over.. it’s one of those mitigating backdoora that becomes system and then impossible to vleean it creates a virtual machine on ur pc that’s not visible to you..
I can't stress this enough.
Borrow a friend's (clean) laptop to configure your new router (without it being connected to the ISP at all). Do not have the hacked router connected to your ISP, or your network.
There is nothing in your home (or anything that visited/connect to your home network) that I would trust at this point.
Nah I know that’s why I bought separate internet and a raspberry im
Formatting everything from phones Tony’s let’s to pcs but it’s so persistent it comes back after an offline boot I think it’s stored in like a virtual disk in memory it’s a small file to execute a command to run a a task that’s runs powershell etc etc
Apparently, the hack stole all the punctuation keys from your keyboard too. Lol
Makes it very hard to understand what you are trying to say.
"Keep getting hacked .... "
Then look at the mistakes you are making with the basic router settings. Turn off Telnet and for SSH only allow from LAN , turn off Access from WAN .
How many other people are here with your issue?
