kernel: Dead loop on virtual device vlan2, fix it urgently!
Sg1
Are this errors normal? I have a lot of them in the log... Running latest Merlin. AC87U.
Sep 28 14:35:48 dnsmasq-dhcp[18391]: DHCPACK(br0) 192.168.1.4 00:06:dc:82:20:65
Sep 28 14:36:05 kernel: Dead loop on virtual device vlan2, fix it urgently!
Sep 28 14:36:12 kernel: Dead loop on virtual device vlan2, fix it urgently!
Sep 28 14:36:15 kernel: Dead loop on virtual device vlan2, fix it urgently!
Sep 28 14:36:16 kernel: Dead loop on virtual device vlan2, fix it urgently!
Sep 28 14:36:20 kernel: Dead loop on virtual device vlan2, fix it urgently!
Sep 28 14:37:37 kernel: Dead loop on virtual device vlan2, fix it urgently!
Sep 28 14:46:12 rstats[2655]: Problem loading /mnt/TOURO/web_his/tomato_rstats_000000000000.gz. Still trying...
Sep 28 15:01:13 rstats[2655]: Problem loading /mnt/TOURO/web_his/tomato_rstats_000000000000.gz. Still trying...
Sep 28 15:16:13 rstats[2655]: Problem loading /mnt/TOURO/web_his/tomato_rstats_000000000000.gz. Still trying...
Sep 28 15:31:13 rstats[2655]: Problem loading /mnt/TOURO/web_his/tomato_rstats_000000000000
No response?
I got them too:
ep 30 18:03:57 kernel: net_ratelimit: 5 callbacks suppressed
Sep 30 18:03:58 kernel: Dead loop on virtual device vlan2, fix it urgently!
Sep 30 18:05:06 kernel: Dead loop on virtual device vlan2, fix it urgently!
Sep 30 18:05:07 kernel: Dead loop on virtual device vlan2, fix it urgently!
Sep 30 18:05:19 kernel: net_ratelimit: 2 callbacks suppressed
Sep 30 18:05:19 kernel: Dead loop on virtual device vlan2, fix it urgently!
Sep 30 18:05:27 kernel: net_ratelimit: 20 callbacks suppressed
Sep 30 18:05:27 kernel: Dead loop on virtual device vlan2, fix it urgently!
Sep 30 18:05:32 kernel: net_ratelimit: 19 callbacks suppressed
Sep 30 18:05:32 kernel: Dead loop on virtual device vlan2, fix it urgently!
Sep 30 18:05:33 kernel: Dead loop on virtual device vlan2, fix it urgently!
Sep 30 18:05:37 kernel: Dead loop on virtual device vlan2, fix it urgently!
Sep 30 18:05:51 kernel: net_ratelimit: 2 callbacks suppressed
Sep 30 18:05:51 kernel: Dead loop on virtual device vlan2, fix it urgently!
Sep 30 18:05:52 kernel: Dead loop on virtual device vlan2, fix it urgently!
Sep 30 18:06:16 kernel: Dead loop on virtual device vlan2, fix it urgently!
Sorry NightOwl326, not all of us have the time to search and search and still not come up with a solution. I've sent Merlin so much money for the good work that he does, and his dedication to helping people out, where you're just the opposite.
Sent from my SM-P600 using Tapatalk
@roldogg
Unfortunately, the community has made it clear that you need to learn how to use the Search feature.
So, guess what? I found out that I needed to learn how to use it too. And I found the post you need. Time to share the secret of Search.
Go to the "ASUS Wireless" forum, and perform the search from there for posts there for "dead loop vlan2"
You will come across a thread where a fix is posted by Merlin.
Good luck!
@roldogg
Good luck!
Oh for crying out loud. This has to be run via telnet:
tc qdisc add dev vlan2 root pfifo
If you reboot for any reason you will have to re-enter that script.
The time used to post looking for a spoon fed answer, is the time that was to be used with a single search to find the answer needed. But then your soooooo busy and such, I am sure you don't have the time to read this post.
Well, I flashed back to the original Asus firmware, the latest release, and it fixed all my problems. I know Merlin works hard at what he does, which he doesn't really have to do, and that's why I've donated money multiple times. He can't satisfy every one, but I've tried multiple configurations in his firmware and still, every day, my sys log fills up with those errors. I don't know what was causing it. All I know is the Asus firmware, as much as I'd rather be running Merlin's, has fixed my issue. The only thing I changed is the firmware, so I'm not quite sure why I was getting hundreds, if not thousands, of errors daily, but now it's fixed.
Sent from my SM-T800 using Tapatalk
Sill nothing
tc disc add dev vlan2 root pfifo
Sorry, but after spending the day unhooking all my stuff, reseting the routers back to default, flashing Merlin's new firmware, figuring out got to use telnet, which I did, but whenever I type the command you told me to use, it tells me Object "disk" is unknown. Is there support to be some kind of object in there after tc like a colon, a forward slash, or something? You've spoon fed me crap.
I think he accidently made a typo....try
PS - The last sentence in your previous post should be replaced with 'Thanks in advance for the help.'
I hope you get your problems resolved.
Yes, I was being sarcastic. If it wasn't for forums like this, no one would be able to fix anything. Thank you NightOwl326. I was able to figure out it was a typo. That's the first time I've ever used telnet to access my router. Is that what the custom scripts are used for? To login to the router and have it run a script for more functionality?
As I mentioned earlier in this thread, I'm also using an RT-AC66U setup as an AP. All router functions are disabled including DHCP, so anything connecting to the AP gets its IP from my primary router, an RT-AC87R.
In the LAN settings of the RT-AC87R, under the Route Tab, there is an option to enable static routes. What's the difference between static routes under this Tab and the static IPs under the DHCP Tab? I have static IPs set under the DHCP, but under the Route Tab, it says "This function allows you to add routing rules into RT-AC87R. It is useful if you connect several routers behind RT-AC87R to share the same connection to the Internet." What's the difference between adding a static route and a static IP? Should the IP of an AP behind your primary router be listed here?
