Kernel Fatal Signal 11 After Installing Diversion
alexYQR
Hi Folks. New here so please be kind. I have a GTAXE16000 running 388.1 and just installed Diversion. Things seems to be working well but in my status console I see the following repeating very frequenty.
Is this something I need to look into or be concerned about? Thanks for the help
Dec  6 15:21:52 kernel: potentially unexpected fatal signal 11.
Dec  6 15:21:52 kernel: CPU: 1 PID: 21602 Comm: dcd Tainted: P           O      4.19.183 #1
Dec  6 15:21:52 kernel: Hardware name: GTAXE16000_2GB (DT)
Dec  6 15:21:52 kernel: pstate: 200f0010 (nzCv q A32 LE aif)
Dec  6 15:21:52 kernel: pc : 00000000f7ba29d8
Dec  6 15:21:52 kernel: lr : 0000000080808080
Dec  6 15:21:52 kernel: sp : 00000000ff8ef270
Dec  6 15:21:52 kernel: x12: 0000000000000000
Dec  6 15:21:52 kernel: x11: 0000000000000000 x10: 000000000007e66c
Dec  6 15:21:52 kernel: x9 : 00000000f6afd008 x8 : 00000000000a387e
Dec  6 15:21:52 kernel: x7 : 0000000000000010 x6 : 0000000000000000
Dec  6 15:21:52 kernel: x5 : 00000000000a3884 x4 : 00000000fefefeff
Dec  6 15:21:52 kernel: x3 : 0000000000000000 x2 : 0000000000000000
Dec  6 15:21:52 kernel: x1 : 0000000000000107 x0 : 0000000000000000
This a known issue that has been documented many times that is typically associated with pixelserv (search "dcd Tainted"). Nothing to be concerned about...
It's a memory scribble - e.g. segfault - a task is trying to access memory that either doesn't exist to it, or is corrupted in some way...
It's mostly related to the trend-micro engine, so the workaround is to revoke perms there...
since it is a memory/task related crash, there's potential security concerns obviously...
Switch to Diversion Lite 0.0.0.0 and disable pixelserv-tls - error gone.
