Marko Polo
I get this weird error from time to time without any possible reason:
I cannot access Samba shares and cannot complete SSH-connection successfully. Only router reboot helps.
Any suggestions? Is attached drive is dying?
Aug 6 07:58:49 kernel: xhci_hcd 0000:00:0c.0: WARN: Stalled endpoint
Aug 6 07:58:54 kernel: xhci_hcd 0000:00:0c.0: WARN: Stalled endpoint
Aug 6 07:59:02 kernel: xhci_hcd 0000:00:0c.0: WARN: Stalled endpoint
Aug 6 07:59:04 kernel: xhci_hcd 0000:00:0c.0: WARN: Stalled endpoint
Aug 6 07:59:07 kernel: xhci_hcd 0000:00:0c.0: WARN: Stalled endpoint
Aug 6 07:59:15 kernel: xhci_hcd 0000:00:0c.0: WARN: Stalled endpoint
Aug 6 08:16:51 kernel: sd 0:0:0:0: timing out command, waited 180s
Aug 6 08:16:51 kernel: sd 0:0:0:0: [sda] Unhandled sense code
Aug 6 08:16:51 kernel: sd 0:0:0:0: [sda] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Aug 6 08:16:51 kernel: sd 0:0:0:0: [sda] Sense Key : Hardware Error [current]
Aug 6 08:16:51 kernel: sd 0:0:0:0: [sda] ASC=0x44 <<vendor>> ASCQ=0x81
Aug 6 08:16:51 kernel: sd 0:0:0:0: [sda] CDB: Read(10): 28 00 00 00 01 e2 00 00 08 00
Aug 6 08:16:51 kernel: end_request: I/O error, dev sda, sector 482
Aug 6 08:16:51 kernel: tntfs error (device sda1, pid 9): ntfs_end_buffer_async_read(): Buffer I/O error, logical block 0xe0.
Aug 6 08:16:51 kernel: tntfs error (device sda1, pid 9): ntfs_end_buffer_async_read(): Buffer I/O error, logical block 0xe1.
Aug 6 08:16:51 kernel: tntfs error (device sda1, pid 9): ntfs_end_buffer_async_read(): Buffer I/O error, logical block 0xe2.
Aug 6 08:16:51 kernel: tntfs error (device sda1, pid 9): ntfs_end_buffer_async_read(): Buffer I/O error, logical block 0xe3.
Aug 6 08:16:51 kernel: tntfs error (device sda1, pid 14427): ntfs_mft_record_map(): Failed to map page containing mft record 0xd3 (error 5).
Aug 6 08:16:51 kernel: tntfs error (device sda1, pid 14427): ntfs_mft_record_map(): Failed with error code 5.
Aug 6 08:16:51 kernel: tntfs error (device sda1, pid 14427): ntfs_index_lookup_init(): Failed to map mft record (error 5).
Aug 6 08:16:51 kernel: tntfs error (device sda1, pid 14427): ntfs_index_lookup_by_position(): Failed (error 5).
Aug 6 08:16:51 kernel: tntfs error (device sda1, pid 14427): ntfs_readdir(): Failed to look up index entry with position 0x0 in directory 0xd3 (error 5).
