Diversion Kids mode blocks normal dhcp function
trixt
I had used kids mode/restricted clients mode for some time and it worked, then after upgrading to some Diversion version (5.1 probably?) all my dhcp clients just stopped working, I had to uninstall diversion to fix things, then I pinpointed the problem to the kids mode. As you can see in the log, when the mode was enabled kids-instance of dnsmasq started but main dnsmasq instance failed to start for the reason I don't understand (the port is occupied? by another dnsmasq? then why it can't serve dhcp?), and all normal dhcp clients can't get their addresses. As soon as I disable kids-mode, everything works fine again.
My current Diversion is 5.3, 3004.388.8_2-gnuton1
amtm 4.9.1 FW ASUS RT-AX92U HW: aarch64 Kernel: 4.1.51
Sep 3 23:33:58 rc_service: service 30219:notify_rc restart_dnsmasq
Sep 3 23:33:58 custom_script: Running /jffs/scripts/service-event (args: restart dnsmasq)
Sep 3 23:33:58 custom_script: Running /jffs/scripts/dnsmasq.postconf (args: /etc/dnsmasq.conf)
Sep 3 23:33:59 Diversion: created br0:restricted_devices for 192.168.16.2
Sep 3 23:33:59 Diversion: started separate Dnsmasq instance for restricted devices on IP 192.168.16.2
Sep 3 23:33:59 Diversion: restarted Dnsmasq to apply settings
Sep 3 23:33:59 dnsmasq[30568]: failed to create listening socket for 192.168.16.1: Address already in use
Sep 3 23:33:59 dnsmasq[30568]: FAILED to start up
just noticed similar reports in 5.1 thread and ppl mentioned it worked for them after 5.1.1 fix, but still happens for me even in 5.3
