KRACK WPA2 Vulnerability Exposed
On Linux, `wpa_supplicant` is used to perform that handshake; it's been patched already on RHEL and CentOS at least. The drivers should not be vulnerable, as far as I understand it.
That first CVE I listed only affects Windows. No idea about the second one, but Intel does list it as having been fixed in their driver release.
Also on Ubuntu/Mint....I was offered the wpa update yesterday.
[sfx2000]
It's a client side vuln - linux and android are high at risk, OpenBSD released a patch for their wpa supplicant, and I expect other OS's to release as well.
AP's are not impacted - however, repeats (as they are clients) are vulnerable.
Yes, I heard that Microsoft has already released a patch for this...in their last cumulative.
On the other hand, routers and a IoT devices all commonly use embedded Linux kernels, so there's that.
Just the other day I had our solar panel installer turn off the wifi between the solar panel monitor and our router, and it's now using powerline networking. Still have a lot of unpatched clients, though *sigh*. Have to wait for Apple and Google to get on it.
ONE of the first Routers to get the WPA KRACK fix is the Dovado Routers
New Firmware containing fixes for WPA KRACK.
VERSION: 9.0.7
Seems like a lot of companies are confused about the flaw. Chamberlain claimed their products weren’t affected because all their traffic is encrypted. It’s my understanding is that doesn’t completely mitigate the flaw, it just means traffic can’t easily be sniffed.
If all traffic is encrypted on top of the WPA2 WLAN communication (like having only https communication) you are fine. :cool:
Update: SSL can also be attacked... ...but this is a different attack!
Still you are not effected by the KRACK attack as the hacker might be able to hack WPA2, but not SSL to read your data... ...hopefully! :rolleyes:
Erm... not really - HTTPs can be attacked as well - sslstrip is but one example...
...and that's until the next Heartbleed occurs...
Technically even if all client/server traffic is encrypted can't network traffic like broadcast messages, UPNP, etc still be intercepted?
