Martineau
Part of the Furniture
I'm not 100% sure if this was a change that is now permanently included in the v386.x builds or was a v384.19 'feature'You're a lifesaver, man. That worked.
So, to be clear, I have to turn on the VPN, run the script, and also run:
Code:ip route del 0.0.0.0/1 ip route del 128.0.0.0/1
Is there any way to get this to happen automatically when I turn on the VPN?
The easiest solution would be to include the two commands in the
PPTP_Select.sh script assuming it is always called manually once the VPN is UPe.g. see this post for a technique to auto=execute
PPTP-Select.sh upon a WAN event.![]()
l2tp vpn client for only one device
I don't know if this is the correct thread to post this question but since I'm running Merlin firmware will ask here anyway. I have a vpn subscription from a provider that offers only l2tp protocol, but my need is to connect only 1 device to this server as I'm using it to watch iptv which is not...www.snbforums.com
