Lan DHCPv6 should be an option when selecting Tunnel 6rd
Poul Bak
Router: ASUS RT-AC68U
On Ipv6 page in the GUI, you can select either 'Native' or one of the tunnels. When I select 'Native' (or 'Static') I get options to choose between 'Stateless' and 'Stateful' which enables DHCPv6 on LAN as shown here:
However, if you choose 'Tunnel 6rd', then there's no option for 'Stateless' or 'Stateful' (and hence no DHCPv6).
There SHOULD be this option.
On LAN, there SHOULD be no difference between 'Native' and 'Tunnel'. Thats a matter between the router and the ISP.
One of the reasons I want to use DHCP is the auto DNS (local computernames gets added to the router's DNS lookup table).
So, please add DHCP option for tunnels too.
