LAN port isolation HTTPS (TLS/SSL failure)
CiViC321
Hi all
I isolated a LAN port on a AX-88U using the method as described here https://wu.renjie.im/blog/network/ax88u-vlan/ by Renjie Wu. Props to you sir.
It is used to isolate some equipment (cameras and NVRs) that belong to the neighborhood I live in. It worked like a charm for a while but now TLS/SSL handshaking fails sometimes.
There are two subnets: 192.168.1.0 and 192.168.150.0. dot-150 is isolated that it can't access clients on dot-1 and only a few services like DNS and NTP on the main router (192.168.1.1). Some HTTPS websites fail on dot-150 which works perfectly on dot-1. I used tcpdump and discovered that during the TLS/SSL handshake no "server hello" is received for some websites, i.e. stackoverflow.com fails but google.com works.
I can't find any mechanism that could cause this on the router. I disabled the firewall and AIprotection but this changed nothing.
Any ideas would be welcome.
D
Replies
57
Views
23K
