Tutorial LAN port isolation on Asus Merlin example
  • Thread starter Thread starter Deleted member 62525
  • Start date Start date
Thanks, I crossed posts with you here. Didn't see this until I already posted my reply. I'm not sure that I want all of the same traffic rules as him with the remote access and some interactions allowed between the bridges that he describes. I suppose I could try this verbatim as proof of concept, but I would like to limit this to just keeping the br100 without any intranet access.
I understand. But when the OP claims it works as-is, then you decide to change it before proving it to yourself, there's no way to know if it's YOU that broke it w/ your changes. Let's just make sure your client gets an IP assignment w/ DHCP and can access the internet, minimally. THEN worry about tightening it down w/ changes.
Excellent point. And correct because I did the firewall script as you posted, unmodified, and now it works! Thank you!!
The device doesn't show up in the Client List of the Network Map tab in the WebUI. Not a big deal, and maybe that's expected, but I find it interesting.
I guess the only parts of the firewall script that concerns me are these. Will try to comment out one at a time and see if it makes any difference.
# Allow new incoming connections from br100
iptables -I INPUT -i br100 -m state --state NEW,RELATED,ESTABLISHED -j ACCEPT
# Allow br100 access the web UI and SSH of the main router
iptables -I INPUT -i br100 -p tcp --dport 80 -j ACCEPT
iptables -I INPUT -i br100 -p tcp --dport 443 -j ACCEPT
iptables -I INPUT -i br100 -p tcp --dport [YOUR SSH PORT] -j ACCEPT
Follow-up. I tried removing these individually and it broke. Either the isolated LAN lost internet connectivity or non-tunneled devices on the main LAN lost internet connectivity. Anyone know why that would be?
I'm trying to decipher what all these do and the consequences of keeping them https://linux.die.net/man/8/iptables but not making much headway. Can anyone shed some light on these?
Thank you!
Thank you!
The last 2 lines allow br100 lan access to router http and https ports. Based on your requirements you don’t need that. The first rule you quoted is to allow new connections from br100 lan segment. You will need that.
I don't know what device you have on new br100 lan, but make sure this device gateway is properly - in example case it is 192.168.150.1, and DNS is set to router IP address (if your router DNS Filter is set to "router").
@dcballers
Glad you got it working.
What I've posted below is a firewall-start script (which can be pasted into an ssh window) that's probably more appropriate to most users. All it does it allow dhcp, dns, and icmp (ping) to the router. And if you use the public DNS servers I provided in the dnsmasq file (8.8.8.8 and 8.8.4.4), you don't even need to allow dns. I allow ping simply for diagnostic purpose, but that could be eliminated too.
Any device on br100 can configure itself w/ DHCP, access the router's DNS server, ping the router, and access the internet. br100 can't initiate communications w/ other bridges (e.g., br0), but br0 can initiate communications w/ br100, and br100 can reply.
cat << "EOF" > /jffs/scripts/firewall-start
#!/bin/sh
WAN_IF="$([ $1 ] && echo $1 || echo $(nvram get wan0_ifname))"
# limit br100 to essential router services (dhcp, dns, ping)
iptables -I INPUT -i br100 -j REJECT
iptables -I INPUT -i br100 -p icmp -j ACCEPT
iptables -I INPUT -i br100 -p tcp --dport 53 -j ACCEPT
iptables -I INPUT -i br100 -p udp --dport 53 -j ACCEPT
iptables -I INPUT -i br100 -p udp --dport 67 -j ACCEPT
# limit br100 to wan access
iptables -I FORWARD -i br100 -j REJECT
iptables -I FORWARD -i br100 -o $WAN_IF -j ACCEPT
iptables -I FORWARD -i br100 -m state --state RELATED,ESTABLISHED -j ACCEPT
EOF
chmod +x /jffs/scripts/firewall-start
Beware, I had no way to test it. I don't own an RT-AC86U. But at least w/ my RT-AC68U, it didn't generate any syntax errors.
P.S. Sorry. I had to change the script. I just realized the prior one would interfere w/ AiProtection on br0.
Thanks for your reply here. Maybe this is a term of art I do not understand, but what throws me off is that, "# Allow new incoming connections from br100" sounds to me like, "allow br100 to initiate connections with other things, such as br0". However, I sense that isn't correct?
Not sure I 100% follow the suggestion in your second part because there may be a word missing after "properly", but the device I have on the new br100 lan is a secure gateway with a wifi router on the back of it. I didn't define a static IP for it if that's what you're asking because I did not know the MAC address as the gateway device is new and it's not listed anywhere on it. Instead I enabled DHCP using some code from @eibgrad. What might be the consequences of doing it this way given the explicit call out in /services-start to 192.168.150.1?
The wifi router behind my br100 lan gateway is accessible by 192.168.1.1 in a browser when I am connected to its wifi. When I am on that br100 wifi I can still connect to my main ASUS via 192.168.50.1 in the browser -- perhaps this is because of the http and https port access that your original script provides?
Back on the main br0 wifi, neither 192.168.150.1 nor 192.168.1.1 take me anywhere in the browser, nor a few other random 192.168.150.x. If I understand correctly, I think this is by design in your original script, the exception being a couple of specific ports that you allowed.
I really appreciate this tutorial you started!
@dcballers
#!/bin/sh
WAN_IP="$([ $1 ] && echo $1 || echo $(nvram get wan0_ifname))"
iptables -I INPUT -i br100 -p tcp --dport 67 -j ACCEPT
iptables -I FORWARD -i br100 -o $WAN_IP -j ACCEPT
EOF
Thanks for this! I like those access rules that you described - sounds like just what I'm looking for. I will give it a try over the weekend.
I am glad you have it working.
Colin, could you say how the AX86U differs, please? I’ve searched but can see how to get this info.
The radio interfaces on the AX86U are eth6 and eth7 rather than the AC86U's eth5 and eth6. There may be other differences, I haven't paid much attention to the VLAN discussions.
Thanks, sounds as if the wireless interfaces have been bumped up a number due to the extra 2.5g LAN port.
Se você tiver apenas IPs estáticos na nova LAN, não precisará fazer mais nada. Apenas atribua a cada cliente IP estático no novo intervalo de sub-rede da LAN. Por exemplo, se você tiver configurado um novo segmento com "
ifconfig br100 192.168.150.1 netmask 255.255.255.0", apenas atribua IP de clientes dentro deste intervalo de IP. Isso é tudo o que você precisa.
Por outro lado, se você precisar de DHCP para o novo segmento de LAN, adicione o seguinte código em /jffs/configs/dnsmasq.conf.add e reinicie o dnsmasq.
interface=br100
# Intervalo DHCPv4: 192.168.150.2 - 192.168.150.254, máscara de rede: 255.255.255.0
# Tempo de concessão do DHCPv4: 86400s (1 dia)
intervalo dhcp=br100,192.168.150.2,192.168.150.254,255.255.255.0,86400s
# Roteador DHCPv4 (opção 3): 192.168.150.1
opção dhcp=br100,3,192.168.150.1
If you will have only static IP's on the new LAN you dont need to do anything else. Just assign each client static IP in the new LAN subnet range. For example, if you have configured new segment with "
ifconfig br100 192.168.150.1 netmask 255.255.255.0", just assign clients IP within this IP range. This is all you need.
On the other hand, if you need DHCP for thie new LAN segment add the following code to /jffs/configs/dnsmasq.conf.add and restart dnsmasq.
interface=br100
# DHCPv4 range: 192.168.150.2 - 192.168.150.254, netmask: 255.255.255.0
# DHCPv4 lease time: 86400s (1 day)
dhcp-range=br100,192.168.150.2,192.168.150.254,255.255.255.0,86400s
# DHCPv4 router (option 3): 192.168.150.1
dhcp-option=br100,3,192.168.150.1
another example:
interface=br100
dhcp-range=br100,192.168.150.100,192.168.150.200,255.255.255.0,86400s
dhcp-option=br100,6,8.8.8.8,8.8.4.4
dhcp-option=br100,15,br100.dmz
dhcp-option=br100,44,192.168.150.1
I'm using AX86U (non Pro).
I followed this guide but devices from br0 can't ping or access device in br100. But I used Network Tools --> Network Analysis in AX86U, I can ping devices in br100. I don't know why.
Please help me.
Thanks in advanced.
