I recently purchased an X99-Deluxe MB, and it has 2 1GB LAN ports. One of the options in the settings is to set these up for LAN teaming. Is there any benefit to using LAN teaming?
If you decide to use the second NIC make sure you have a switch which supports both NICs. If you just plug in 2 NICs from the same machine into an unsupported switch you can slow your network down.
Yeah... I did that. Plugged in 2 nics from my pfSense router into the AP, before I had completed setting up LACP. Killed the LAN pretty fast. That solidified that I was messing with things above my pay-grade, so I gave up (for now...).
I think how much your network will be affected by 2 NICs not setup but connected will depend on how good your spaning tree support is. In a switch with good spanning tree support one NIC will automatically be blocked and run as a redundant port and all is good.
Without spanning tree support the switch will slow down and eventually crash.
That is another way of saying link aggregation. http://en.m.wikipedia.org/wiki/Link_aggregation
You could increase your connection rate or use it for load balancing. The link explains it in much more detail.
It doesn't increase your connection rate, it allows more connections at the same speed.
IE you don't get 2Gbps on a connection with teaming/link aggregation, but you can have two simultaneous 1Gbps connections going.
SMB Multichannel allows an increase in your connection rate (to another source with SMB Multichannel). So you CAN get a 2Gbps connection. Windows 8, 8.1 and Server 2012 ONLY at the moment (well, Windows 10 will have it).
Most of time when you combine things you gain bandwidth not speed. So if you are not using what you already have there will be no gains realized.
You will see the same kind of effect on gig ports as you did with your modems. You just need to be able to saturate the first gig line to realize the benefit of the second. This is assuming both gig ports are setup correctly for teaming or link aggregation on the machine and switch.
PS
Home networks don't have enough network demand to fill a gig pipe from a server. You could do it with 100meg connections and video but gig is just too fast in most cases for home.
Welcome To SNBForums
