Hello,
i have search for days, but i do not understand where my problem is on a RT-AC88U with 386.14_2 firmware,
My setup is simple, after factory reset, i only do this setup : (with Wan unplug)
Set language to english, Enable ssh, Set router ip to 192.168.2.1 and enable wifi 2hgz guest (Access Intranet disable)
After a reboot if i try to ping from lan 192.168.2.x to wifi 2hgz guest 192.168.101.x it do not work
but if i add this rule, it's ok : iptables -I FORWARD -i br0 -o br1 -s 192.168.2.10 -j ACCEPT
after that if i plug wan cable it do not work anymore, even after reboot, even after add the rule again
Any advise ?
Any advise ?
