This seems like a pretty easy thing to do, but my head is spinning with terminology and I just can't get my arms around it.
There are 2 homes each with high speed internet. Both have modem/router supplied by provider which provide landline and wireless connections. One is Google Fiber (which doesn't seem to allow you do much in the way of configuration) and the other does provide a bit more networking options. My goal is simple. I want to be able to ping a device from home A that is inside home B. Now, that device in home B will be a wireless device. I tried to study about Lan-to-Lan VPN using IPSEC, but Google Fiber's router doesn't seem to support it. So, I bought a TP-LINK ER605 router to put inside the home network. Actually I bought 2 so each home would have them. I figured I could use them to set up the VPN, but settings and terminology just got too confusing.
If I plug the cable from the provider's router into the WAN port of the ER605, then it has an IP of 192.168.0.1, which is different than provider's network which is 192.168.1.1. Now I have seen some videos where I can force my ER605 to be on the same 192.168.1.1 subnet, but then I get lost in how to configure the ER605 to create a VPN.
Now I think I could probably get the VPN set up if I plugged both ER605's into the WAN port and follow some videos to configure IPSEC. However, now I'm stuck because neither router can see anything on the wireless network, because that is a different subnet.
First..does any of this make sense? Second, if I do use WAN ports and configure a VPN between them, how can I get the ER605 routers to see the devices on the wireless network (192.168.1.X subnet), or can I configure them so that they are all on the same subnet and still create a VPN?
I know this is a hail mary, but if anyone has done this or can point me to some videos so i can educate myself I would appreciate it.
