My current setup is an AX88U as the main Router, with 5 Zen Wifi Mini boxes acting as mesh devices.
Had the setup for a couple of years and I find it totally unreliable...I probably go no more than 1-2 weeks without an issue of some kind. The mesh nodes either individually or a combination of a few just drop out, reset and start flashing blue. Other times the AX88U will just c**p itself and restart, devices can be connected all day without issue then suddenly get no access or speed off the network. Firmware upgrades are painful....one will update ok, but usually at least one bricks during the update process and I have to factory reset a mesh node and start again.
I have tried factory resetting the whole lot at least twice, tried the merlin bios setup on the AX88U...and yet still the whole thing is flakey. I've made no other changes, have nothing out of the ordinary on the network, some NAS drives, laptops, smart plugs....nothing near capacity etc. Checked I'm on a different channel to neghbours etc in case interference was part of the problem.
I've looked at the logs when the random restarts/mesh node drop outs happen, seems to be lots of kernel messages followed by WLCEVENT messages:
Aug 7 21:10:06 kernel: x3 : 0000000000000000 x2 : 0000000000000001
Aug 7 21:10:06 kernel: x1 : 00000000000000d0 x0 : 00000000000000d2
Aug 7 21:10:27 roamast: ROAMING Start...
Aug 7 21:10:32 wlceventd: wlceventd_proc_event(494): eth6: Deauth_ind D2:FD:4B:F2E:27, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:-62
...but none of it makes sense to me.
On paper I thought it should just work, didn't think the kit was cheap as chips so shouldn't expect a budget service....but now I am running out of ideas, other than ditching the lot and moving away from Asus altogether.....the amount of time I am wasting managing issues with this hardware now means I've had enough.
So just wondered before I ditched it...if anyone else:
a) has a similar setup
b) had similar issues
c) has any suggestions or answers to explain how to fix or where to look to find some causes of the above.
