Latest firmware update
Cary5500
I recently updated Merlin firmware from previous Merlin firmware.
Do I need to do a factory reset after firmware updates?
edit* the reason I ask is because after update internet is terribly slow.
It shouldn't be necessary. Try completely powering off and then turning on the router.
You could try a factory reset and see if that makes any difference.
Backup your settings and JFFS partition before the reset (Administration - Restore/Save/Upload Setting). If it doesn't improve matters you can then restore your old settings if you want to.
How slow is slow? How are you testing this?
It’s mostly from a distance.. The ps4 in the kids bedroom is suffering the worst at 80mgb prior to the update it was 150mgb. Ethernet seems to be pretty on par as before. 300-370mgb. Wi-Fi 5g near the router nets 361mgb. 15ft away it drops to 244mgb
Posting ACTUAL firmware version numbers is never a bad idea :)
What are you using to quantify this speed drop? If you roll back the firmware, do the speed tests return to your expected resulting speeds?
Speed test via app. I haven’t tried to roll back. It looks as though the firmware update was setting 5g to Chanel 44 permanently. I set it to 161 it helped some.
