Lighttpd web server with PHP support through Entware with RTAC87U [solved
phil766
I'm trying install a web server on RTAC87U with lastest merlin firmware.
I successfully install entware, install lighttpd and started the service.
The only problem is that I cannot access my index.html on 192.168.1.1:81.
I didn't change anything in the lighttpd.conf, just leave everything on default.
Can someone help me with the configuration file, do I have to change something in it or in the router settings?
Tx
You probably need to enable port forwarding to port 81.
