David Donlin
All fresh settings handcrafted! last test was wifi now Ethernet - 509/561. Thanks!! Now how should I rebuild moving forward? just load settings or is there a methodical (correct/better way to do this.
In your case enable things like DoT and DNSSEC turn on script support and add AMTM, Skynet then Diversion. Don't enable Traffic monitoring or QOS or AI-Protection or AI-Cloud, just stay away from the Asus and Trend Micro stuff. Add stuff back step by step and reboot each step. The reason for the reboot is so that you can tell if the acceleration settings have been affected.All fresh settings handcrafted! last test was wifi now Ethernet - 509/561. Thanks!! Now how should I rebuild moving forward? just load settings or is there a methodical (correct/better way to do this.
Welcome To SNBForums
