Beauty is, as they say, in the eyes of the beholder.Also I'd be lying if I didn't mention how sexy the WRT1900AC looks.![]()
Tim has already made it crystal clear what the focus of this thread is to be; experiences using the device.
My point is simple, & the pattern here @SNB is regular, when something diverges too much, you spin it off.
Can you say more about the 5GHz performance "inconsistent"? Disconnects? Range problems?Mainly for 5GHz wireless. I've tried a couple of the AC1750 class routers and 5GHz wifi was inconsistent. Same issue w/ the R7000 (overrated and over-hyped IMO). I'm hoping that the WRT1900AC solves this issue.
I think Tim uses a consistent set of clients and propagation / multipath situation.
I wouldn't be surprised if most of the popular press reviews are irregular, or worse, in these regards.
Especially PC world as they have to operate on the cheap these days.
Michael Brown's test methods look good, similar to the open air method I used to use. Only thing missing is the actual measurement method for throughput.Pcworld he talked about everything he used. I wouldn't call any of it cheap. And he presented interesting house elements with his home theater room.
I purchased the WRT1900AC a couple of days ago. No real issues so far. I do like the simplicity of its QOS and GUI. I am getting improved range on 5 GHz than I had with my RT-N66U. After limited testing, one interesting thing is that I noticed is that I am getting better range on 5GHz channel 157 than I am on the other channels. I did have to power cycle the router once due to not being able to log into the router.
Another review with which to compare:
http://www.cnet.com/products/linksys-wrt1900ac-wireless-router/
I don't think the data shows that at all.Interesting... it seems the sterile environment SNB uses really shows the nighthawk as being top notch.
Just read PC World's review of the AC1900 and it has it besting the AC68u by as much as 30% Probably client related but seems to be a sharp contrast to SNB's review.
I actually took the approach of putting as much on the 5ghz this time around on my r7000. And for example my iphone was only showing 2 bars instead of 3 on 2.4ghz the speed was way faster in the 5ghz range. So I think these newer routers just extend the range in 5ghz to negate using 2.4ghz unless its legacy. Thats just my take so far. only about 10 days in though.One interesting comment in the PC World review is something along the lines of
2.4 GHz performance is not as good but that we should be using 5 GHz anyway and that he only uses 2.4 GHz it for legacy single-band clients.
I am a bit surprised by this observation since many of us have discussed the following given the nature of 2.4 GHz (longer effective range at the expense of slower throughput in some situations) versus 5 GHz (shorter effective range, albeit with higher throughput within the effective radius):
The fact that anyone with a more challenging environment (larger home, lots of walls or other obstacles, general non-linear path between router and wireless clients etc.) will likely need to use 2.4 GHz (as opposed to 5 GHz) for wireless clients located at some of the further locations (relative to the router's location in the home).
Does anyone else find the reviewer's observation, regarding reportedly solely needing 2.4 GHz, surprising?
Thread starter | Title | Forum | Replies | Date |
Linksys EA9500 - Local DNS | General Wi-Fi Discussion | 5 | |
P | Linksys Velop WHW03v1 firmware version 1.1.20.211186 | General Wi-Fi Discussion | 0 |
Welcome To SNBForums
