Loosing almost 80% speed through my RT-AC68U.
What version of Merlins firmware are you using? Sounnds like it's very old. Also when you flashed to Asus firmware did you do a factory default reset? If your budget will allow, the AC86U is definitely a step up.
Hi Dave.
I don't recall what Merlin FW I was using, but it was really old. Yes, I did a full reset.
If I can't really use QoS, and my Wi-Fi is fine, then I don't see the point of changing my router as it's working fine in all other areas (I think) ;)
