Hello to everybody,
This is my firt message and Im sorry to be this way but I need some advice.
I have a WRT120n on one room, the room is 4x4 (in meters), it has brick walls, next to this room is another 4x4 room and a 6x4 (the living). There is a door from the routers room to the living, and another door to the other room (room B), also, room B and the living has a door. I hope everyone can "imagine" but it is not a complicated house.
I have a wired computer, a couple of notebooks which are most of the time on the living (one N and one G), a couple of cellphones (N) and an XBOX with a Vonet adapter (G).
I have two problems:
1- The cellphones do not get a good signal, one of them is a Galaxy S2 and it keeps changing his sync speed, starts at 65Mbps and then keeps jumping from 5Mbps to 26Mbps, sometimes around 50Mbps, no more than that.
2- The XBOX has some serious issues, I understand it is not on the best spot (its on the "corner" most away from the router) and the adapter isnt the best but it struggles to get anything.
More data...
- I live in a house, there are no interference from other signals, I mean, there are a couple but are really low.
- With my S2 did some little site survey, the signal says between -70db and -50db around the house, even on the worst spot (the XBOX).
- The N notebook syncs at 120-150 Mbps
- The VONET adapter, while connected to a notebook shows between 10% and 30% signal strength on the XBOX place.
- The S2 even next to the router does not stays at 65Mbps.
- The S2, in the living, at no more that 4 mts from the router in straight line with the open door fluctuates with moments of 5Mbps.
- If I cross my front door (in the living) I lost all of my signal, it is impossible to keep connected out of the house (curious because I see signals from the neighbors)
This is pretty weird, clearly I need more strength, it is not unusual that the notebooks receives signal, it´s bigger and with better antenna, but anyway I shouldn´t have this problems...
So, I cant increase the signal of my WRT120n, should I change it?, will something like a WRT610n give me better signal? (thinking on the same line to be simple, and without entering the EA line, its dual band as the new ones and I dont need more than 300Mbps because I have nothing like that).
What do you think?
Thank you!!!
More data...
What do you think?
Thank you!!!
