Low signal strength around my house (WTR120n)
There is AC wire tracking gadget you can buy cheap and did you try all different channel aas I suggested? you may find certain channel gives better signal. Do you like a router with internal antennas since you mentioned them?
Hi, yes I did there are no noticeable differences between channels, also right now Im on ch 9 with no networks on ch 8 and just one in ch 10.
Ill look into that gadget. And the routers model are based on what I can find in Argentina, mostly linksys, some belkin, asus and netgear, theres tplink also and if this is a good option can be bought on dx or aliexpress.
Thank you all for the suggestions
Enviado desde mi GT-I9100 usando Tapatalk 4 Beta
