Mac Address Cloning
M_M
Probably a stupid question, but… When I clone / change the MAC address of my AC68U router to match the address of my previous router, is it permanently changed or does it go back to the original when the router is reset to the factory settings?
Are there any adverse effects of doing this? The reason I'm asking is that although I do not pay for a static IP, it has not changed in the last 5 years and I would like it to remain the same, but I'm afraid that when I hook up the new router, it will change.
Thanks in advance!
M_M
Thanks in advance!
M_M
It's not permanent. A factory default reset will revert back to the built-in MAC.
Changing MAC will most likely get you a new IP from your ISP indeed.
