[MAC Filter] Functionality
PeterLiljedahl
Hello, it has probably been asked before.
Is it possible to move the tab [Wireless MAC Filter] to maybe under the [LAN] or [WAN] section and relabel the tab to [MAC Filter] ?.
Under this [MAC Filter] tab we created, we can now select ethernet MACs such that we can fully control added devices.
We could use a dropdown list and add devices previously added under the [DHCP Server] tab to easy management.
In my case I have a RT-AX58U_V2 with Gnutons software if that matters in this case.
Thanks to Merlin, Gnuton and all contributors.
Yes I am aware this is currently a wifi only filtering mechanism.
Since ethernet MACs are identical I thought the implementation
would be similar to that of wifi but I am not a programmer.
Maybe it is done at silicon level and therefore cannot be realized.
It shouldnt affect the performance since the check is performed
only when the cable is plugged in similar to the initial wifi check.
