Malware Filter / bad host IPSET
and it works when you run it manually? do you have entware installed ?
and last but not least mind printing the value of this echo $TMP
Yes I got entware installed, it works perfect if I run it manually
/root# echo $TMP
/opt/tmp
good morning, just to confirm this is the result in the syslog of the manual run
eb 20 14:46:32 kernel: net/ipv4/netfilter/ip_set_iphash.c: iphash_retry: rehashing of set malware-update triggered: hashsize grows from 39366 to 59049
Feb 20 14:46:59 system: Malware Filter loaded 18433 unique ip addresses.
and now the cron run
Feb 21 00:00:00 crond[247]: USER xxx pid 6089 cmd /tmp/mnt/sda1/malware-filter/malware-block
Feb 21 00:00:06 system: Malware Filter loaded 0 unique ip addresses.
So you can take a look when you have time, thanks
Hey everyone havent had time this weekend to fix the script still recommending using revision 15 until the issue is fixed. Just wanted to update everyone so there is no misunderstandings.
4. One rare problem with xargs is end of file string, by default end of file string is "_" and if this string occurs in input the rest of input is ignored by xargs. Though you can change end of file string by using option "-eof". <---do you think your new file naming convention may be somehow tripping the xargs up when the script is run from the cron rather than directly?
give me the one liner fix in pm and ill look at it and update if it works, haven't had a lot of time to fix issues like this when i started my new job so im more then greatful for patches :)
Just a wild guess actually.... i haven't copied his setup to try and reproduce his bug.... @shooter40sw might want to try it himself if you dont have time..... just change the underscores in the file names so
"$TMP/malware_filter_sorted.part" becomes "$TMP/malware-filter-sorted.part" for example.
the cleanup can be fixed later if it works
If not it has to be some weird shell variable problem with $TMP... i have a feeling a job run from cron doesn't have the same environment
thinking if i hardcode /tmp instead of variable $tmp it might work better, made the changes in git.
I experienced the same issue with the cron job not working. It appears that both changing $TMP to /tmp and changing the underscores to dashes are required to resolve the issue.
kewl, if you got the time please review my git (to other users please dont use this version its WIP), if it all works then ill update as soon as ive tested or if someone confirms the review :)
Malware filter in git correctly runs from cron job as well as from command line on both mips and arm routers.
Rev 17, sorry for the delay :)
#!/bin/sh
# Author: Toast
# Contributers: Octopus, Tomsk, Neurophile, jimf, spalife, visortgw
# Testers: shooter40sw
# Revision 17
blocklist=/jffs/malware-filter.list                     # Set your path here
failover=eth0                                           # Change only if WAN interface is not detected.
retries=3                                               # Set number of tries here
regexp=`echo "\b([0-9]{1,3}\.){3}[0-9]{1,3}\b"`         # Dont change this value
case $(ipset -v | grep -oE "ipset v[0-9]") in
*v6) # Value for ARM Routers
    MATCH_SET='--match-set'
    HASH='hash:ip'
    SYNTAX='add'
    SWAPPED='swap'
    DESTROYED='destroy'
    OPTIONAL='family inet hashsize 2048 maxelem 65536'
     ipsetv=6
     lsmod | grep "xt_set" > /dev/null 2>&1 || \
     for module in ip_set ip_set_hash_net ip_set_hash_ip xt_set
     do
          insmod $module
     done
*v4) # Value for Mips Routers
    MATCH_SET='--set'
    HASH='iphash'
    SYNTAX='-q -A'
    SWAPPED='-W'
    DESTROYED='--destroy'
    OPTIONAL=''
    ipsetv=4
     lsmod | grep "ipt_set" > /dev/null 2>&1 || \
     for module in ip_set ip_set_nethash ip_set_iphash ipt_set
     do
          insmod $module
     done
esac
check_online () {
if [ -z "$(which nvram)" ]; then
iface=`grep "$failover" /proc/net/dev`
if   [ -n "$iface" ]; then
     if [ $(curl -s https://4.ifcfg.me/ | grep -oE "\b([0-9]{1,3}\.){3}[0-9]{1,3}\b") ]
     then get_list; fi
     else exit 1; fi
else iface=`nvram get wan0_ifname`
     then get_list; fi
     else exit 1; fi
fi }
get_list () {
url=https://gitlab.com/swe_toast/malware-filter/raw/master/malware-filter.list
if [ ! -f $blocklist ]
then wget $url -O $blocklist; get_source; else get_source; fi
get_source () {
    wget -q --tries=$retries --show-progress -i $blocklist -O /tmp/malware-filter-raw.part
        awk '!/(^127\.)|(^10\.)|(^172\.1[6-9]\.)|(^172\.2[0-9]\.)|(^172\.3[0-1]\.)|(^192\.168\.)/' /tmp/malware-filter-raw.part > /tmp/malware-filter-presort.part
    cat /tmp/malware-filter-presort.part | grep -oE "$regexp" | sort -u > /tmp/malware-filter-sorted.part
run_ipset () {
echo "adding ipset rule to firewall this will take time."
ipset -L malware-filter >/dev/null 2>&1
if [ $? -ne 0 ]; then
    if [ "$(ipset --swap malware-filter malware-filter 2>&1 | grep -E 'Unknown set|The set with the given name does not exist')" != "" ]; then
    nice -n 2 ipset -N malware-filter $HASH $OPTIONAL
    if [ -f /opt/bin/xargs ]; then
    /opt/bin/xargs -P10 -I "PARAM" -n1 -a /tmp/malware-filter-sorted.part nice -n 2 ipset $SYNTAX malware-filter PARAM
    else cat /tmp/malware-filter-sorted.part | xargs -I {} ipset $SYNTAX malware-filter {}; fi
fi
else
    nice -n 2 ipset -N malware-update $HASH $OPTIONAL
    /opt/bin/xargs -P10 -I "PARAM" -n1 -a /tmp/malware-filter-sorted.part nice -n 2 ipset $SYNTAX malware-update PARAM
    else cat /tmp/malware-filter-sorted.part | xargs -I {} ipset $SYNTAX malware-update {}; fi
    nice -n 2 ipset $SWAPPED malware-update malware-filter
    nice -n 2 ipset $DESTROYED malware-update
fi
iptables -L | grep malware-filter > /dev/null 2>&1
    nice -n 2 iptables -I FORWARD -m set $MATCH_SET malware-filter src,dst -j REJECT
else
    nice -n 2 iptables -D FORWARD -m set $MATCH_SET malware-filter src,dst -j REJECT
fi }
cleanup () {
logger -s -t system "Malware Filter loaded $(cat /tmp/malware-filter-sorted.part | wc -l) unique ip addresses."
find /tmp -type f -name 'malware-filter-*.part' -delete
check_online
run_ipset
cleanup
exit $?
just outta curiosity how much is your malware filter catching ?
ipset -L malware-filter | wc -l
i got 7 lists in my filter and my block is ~49K of blocked IP to be specific 49815
just remember that its minus 7 of the given value since its seven lines of text that gets counted into the wc -l command
/jffs/scripts# ipset -L malware-filter | wc -l
ipset v6.29: The set with the given name does not exist
0
