Merlin 3.0.0.4.374.34 BW Monitor problem?
Chris313AllNight
As stated in the title I'm having problems with the BW monitoring capabilities. Nothing that I select for Last 24, daily or monthly show any stats. It's all blank or 0 usage.
I'm having to rely on my ISP meter, which may not always be accurate.
Any suggestions?
Any suggestions?
Everything is working as expected on my RT-N66U. All have values.
You did not state what router you are using.
--bill
Oh, yes. Bleh. N66U
Make sure you configure it under Tools -> Other Settings. Note also that it only works if the router is fronting the Internet as a router, not if it's acting as an AP or a Repeater.
Perhaps you changed usb memory ? I had this same behaviour when I renamed the USB stick. The solution RMerlin stated to ma. Sure the configuration is right did the job for me.
