uKasa uKasa - A utility script that manages Kasa smart outlets and switches with Asuswrt-Merlin routers
This is my power strip. I have 2 of them. From the support page you can find there's different hardware version. Mine is version 1 and 2. In case something went wrong by PM I attach my log files here for your reference. Looks like the attachment need has file extension. So I just add .txt to them.
Thanks. It looks like the response from the power strip had a type field of "null". Wonder if the power strips need a different decode.
Let me look into this.
Thanks!
NOTE nmap is usually pretty good about finding all the Kasa devices. Once in a while it might miss one. If the number of devices it reports found doesn't match with what you believe, run ukasa in discover mode
Have you addressed this security concern?
nmap is bad news on a bastion host - this really isn't something you want installed on a device that can be exposed to the internet.
The last thing you want running on your firewall is a tool that is specifically designed to do network recon for addtional vulns and targets for exploits...
If someone has the ability to execute malicious code on your router I think they have a lot bigger ideas and capability then using a niche script that’s preinstalled to communicate with some power strips.
I have put together YetAnotherUtility that runs on Asuswrt-merlin routers and is used to manage and operate TP-Link Kasa Smart Plugs and Switches. It can show the present state of the plug or switch (Off/On) and if supported how much power it is supplying (along with line voltage). There is also a "monitor" mode that will show the line voltage, current, Watts and Watt Hours continually (until Enter is pressed)
I originally did this for some issues I was having with an AiMesh node. At times, the node would go "offline" and I found that a power cycle always brought it back.
What problem are you trying to solve here? The Kasa app works fine, and better yet, it works over the internet.
If the Kasa device is dropping offline, this doesn't require a new application/script...
Fix the AIMesh issue first.
Have you looked at most of these Asus Add-On from a security perspective?
I guess not...
Oh boy...here we go again lol
I've run George Georgovassilis' version of this on my server for years now, works great, nice to see it adapted for use with asuswrt-merlin
edit: Just realized the one I linked is a different version than what I have saved. Mine is much more complex, the git version is much simpler and works after adding -w1 to the netcat command (on my debian system).
Don't provide an easy door to be opened...
I'm really surprised that folks don't consider this...
@Adamm, @sfx2000, I always really appreciate getting both perspectives.
Even if I err on the side of security.
@JGrana I found your script while trying to fix an issue with a buggy HP printer that occasionally needs a re-power to remain reachable; thanks it totally works! Along the way, I discovered an issue that can crop up when GNU NetCat is installed on the AsusWRT Merlin router using Entware (I needed it to use nc -z for checking the printer's status). GNU NetCat will take over as the default NC rather than the BusyBox NetCat and the uKasa script will hang for a long time when running the send_to_plug() routine. I fixed the problem on my router by editing the routine to hard code the location of the BusyBox NetCat binary:
Before:
Bash:
send_to_plug() {
   ip="$1"
   port="$2"
   payload="$3"
   if ! echo -n "$payload" | base64 ${BASE64DEC} | nc $NCOPTS $ip $port
   then
      echo "couldn't connect to $ip:$port, nc failed with exit code $?"
   fi
After:
Bash:
send_to_plug() {
   ip="$1"
   port="$2"
   payload="$3"
   if ! echo -n "$payload" | base64 ${BASE64DEC} | /usr/bin/nc $NCOPTS $ip $port
   then
   fi
Maybe not an ideal fix, but a NetCat vendor conflict may be important to keep in mind.
Before:
Bash:
send_to_plug() {
   ip="$1"
   port="$2"
   payload="$3"
   then
   fi
After:
Bash:
send_to_plug() {
   ip="$1"
   port="$2"
   payload="$3"
   then
   fi
Thanks @dave1000 . I'll update the github source!
First, thanks @JGrana for this tool. I've been using this for some automation for about 2 months, which I recently noticed was broken. Being transparent, I haven't done much troubleshooting other than rebooting my router. I wanted to share what I'm experiencing first before changing anything.
My Setup
* RT-AX86U Pro, Merlin 3006.102.4
* Installed latest version of your script (about 2 months ago)
* Entware, Skynet, vnStat, scMerlin, Dual WAN Failover
Second data point is that I had initially installed this on one of my Mesh nodes for testing, and it is also now producing the same error:
od: cannot skip past end of combined input
I'm trying to remember my order of operations here, but I believe the culprit may be due to implementing Dual WAN (in the router, along with the Dual WAN Failover from amtm). I swear I tested this end to end after that but may be wrong.. I haven't updated to the latest Merlin (for reasons), haven't updated Entware, and have even had the Kasa switches blocked from internet access so nothing can be updated/changed there. The Dual WAN Failover is the only potential change.
I get that error every time I run the script, no matter which command I try to run. I'm no longer able to query the state of the device (returns "OFF" even though it's on). Trying to run "ukasa refresh" finds the devices, but isn't able to pull the names or other info:
root@RT-AX86U_Pro-FE60:/jffs/scripts# ukasa refresh
myip  subnet port: 192.168.5.1 192.168.5.0-255 9999
Scanning local network for Kasa plugs and switches
This can take a minute or two...(ignore any RTTVAR messages)
Checking devices and names...
Found 2 Kasa devices on the network
ukasa: Here are the Kasa devices found:
Device IP      Hostname  Model    Type  Features  Alias
192.168.5.201  b00027    Unknown
192.168.5.202  b00364    Unknown
The fact that it worked perfectly on 2 Asus devices and is now broken on both of them (with no other known changes) makes me think the Dual WAN setting and/or the Dual WAN Failover script is messing with the LAN broadcast or something to that effect. I might have some "approved downtime" this weekend to disable Dual WAN and uninstall the Dual WAN Failover script and see if that restores the ukasa functionality, although I really need Dual WAN to work.. Any ideas? Am I barking up the right tree? Does anyone else have this working along with Dual WAN?
Sorry you’re having issues! The error from od has to do with the decode function (the Kasa devices return encoded messages). od is told to skip the first 4 bytes of the message (header).
It appears that it is having issues getting the response message from the devices.
See how big the file /jffs/addons/ukasa/kpresonse is. This would be the file od is trying to decode.
Thanks @JGrana. /jffs/addons/ukasa/kpresponse is empty. It does find the 2 devices, but something else is going wrong:
root@RT-AX86U-F1B8:/jffs/addons/ukasa# ls -l
-rw-rw-rw-    1 root    root             0 Oct 29 19:44 kpresponse
drwxrwxrwx   2 root    root             0 Oct 28 20:41 saved
-rw-rw-rw-    1 root    root            49 Oct 28 20:41 ukasa.conf
-rw-rw-rw-    1 root    root            58 Oct 29 19:44 ukasa.devices
-rw-rw-rw-    1 root    root            38 Oct 29 19:44 unknownkasa1
-rw-rw-rw-    1 root    root            38 Oct 29 19:44 unknownkasa2
I uninstalled and reinstalled this last night on my mesh node. Same behavior. I guess it now seems obvious that od is trying to trim bytes that don’t exist. So now the mystery is why that file is being written null. I can probably piece it together from your script, but do you have a quick one liner I can run to query manually and see the raw output? Or any other debugging ideas?
Of course when most things break, it's caused by change.. I disabled dual-WAN and rebooted a couple times, that being the only known change applied since this did work correctly. The error persists though, so I think that can be ruled out as a culprit.
I was able to query manually and can get the following json response, although prepended with 5 characters I cannot seem to copy+paste here:
"system":{"get_sysinfo":{"sw_ver":"1.0.13 Build 240117 Rel.162355","hw_ver":"5.0","model":"HS103(US)","deviceId":"8006EB98A494DA1DBB2E6F87D4587ACB24070733","oemId":"211C91F3C6FA93568D818524FE170CEC","hwId":"B25CBC5351DD892EA69AB42199F59E41","rssi":-16,"latitude_i":<redacted>,"longitude_i":<redacted>,"alias":"Starlink","status":"new","obd_src":"tplink","mic_type":"IOT.SMARTPLUGSWITCH","feature":"TIM","mac":"3C:6A:D2:B0:00:27","updating":0,"led_off":0,"relay_state":0,"on_time":0,"icon_hash":"","dev_name":"Smart Wi-Fi Plug Mini","active_mode":"none","next_action":{"type":-1},"err_code":0}}}
Using a python3 script, I'm also able to reliably query the switch state:
python3 - <<'PY' | jq '.system.get_sysinfo.relay_state'
import base64,socket,sys
payload=base64.b64decode('AAAAI9Dw0qHYq9+61/XPtJS20bTAn+yV5o/hh+jK8J7rh+vLtpbr')
s=socket.create_connection(('192.168.5.201',9999),7)
s.settimeout(1.0)
s.sendall(payload)
buf=bytearray()
try:
    while True:
        chunk=s.recv(4096)
        if not chunk: break
        buf.extend(chunk)
except socket.timeout:
    pass
s.close()
if len(buf)<=4: sys.exit(2)
cipher=buf[4:]
key=171
plain=bytearray()
for c in cipher:
    p=c ^ key
    plain.append(p)
    key=c
sys.stdout.buffer.write(plain)
PY
I've been reading up on it but still not quite sure how to then fix what still appears to be a parsing issue with the 'od' command based on the json output it's receiving. I'm of course also curious why this suddenly broke for me but nobody else seems to be having the same issue. I'll keep plugging away in some free time and see if there is anything else I can figure out.
OK, so I've narrowed this down to a netcat issue. Seeing @dave1000's post above, I tried installing GNU netcat from Entware and changed the variable in the script to use that version, and it works! Of course, as dave1000 said, it hangs for a really long time (exactly 60 seconds), so this isn't ideal. Knowing this now, questions remaining are:
1) Any ideas on why the BusyBox (v1.25.1) version of nc would stop working and/or how to troubleshoot this? (And still curiously, why did it stop working simultaneously on 2 different Merlin systems on my network?)
2) Any ideas on how to get the GNU version of nc to not hang for a minute before returning results? Side note: I tried adding '-c' per some online info (NCOPTS="-w 7 -c"), but this then seems to close the TCP connection before the json results are returned and doesn't work.
Final update until I have more time.. After installing the Entware/GNU version of netcat, the "uname -o" command is now returning "GNU/Linux" instead of "ASUSWRT-Merlin" like it should. Removing netcat and forcefully reinstalling BusyBox doesn't change the behavior. This breaks the script completely to the point I can't install/uninstall it without removing that check. I'm out of ideas and seemingly going backwards in productivity so am calling it a night.
Ouch. I am running firmware 3006.105.5 on my AX88U Pro. I just checked and I running nc via BusyBox.
I am confused that simply installing nc from Entware would cause uname to report incorrect results.
I have a spare AX58 running Pi-hole. I installed Entwares netcat and uname still reports Asuswrt-merlin
In the mean time I have uploaded to github a debug version of ukasa. It keeps a copy of the raw data returned in the query function.
I also added a debug flag that turns on xtrace before the call to get the data from the kasa device. It needs to be the first command in the command line. i.e.:
ukasa debug 192.168.1.54 state
ukasa update
should see the new file and download it. Assuming you can get back to uname sanity...
If you see lots of text scroll by, let me know. od shouldn't have an issue.
If not, then the call to retrive the data failed.
Hi @SoFluffy, I'm glad you found my post helpful! Were you able to solve the issue with od? Although I've not had the opportunity to play with AIMesh or dual-wan, I'm willing to help you with this, if I can.
I have not experienced the issue of having "GNU/Linux" instead of "ASUSWRT-Merlin" from uname -o, but I have also kept upgrading since installing uKasa and am currently on Merlin 3004.388.10_2 (RT-AX68U).
I agree with you and @JGrana that the od error is likely due to od trying to skip past bytes in an empty kpresponse file, but it looks like you are able to communicate (at least, in part) with your Kasa devices. My first thoughts are you could have a full /jffs partition (unlikely) or, possibly, because you are using AIMesh, there could be some kind of loop in your network that is alleviated by the long hang in GNU nc which I experienced (sort of an additional wait state). When you manually obtained the kpresponse data did you use a telnet session? If so, how did it go? Was there a delay?
For the same reason, it may also be interesting to see what ping times you receive to the Kasa devices with larger packet sizes.
I eventually solved my printer issue when I discovered I had used the same static IP as the printer on a game console that intermittently turned on to check for system updates, doh!
As a result, I haven't used my Kasa outlets and uKasa for a while, but with Christmas coming I'll probably be dusting them off (for the tree and lights), at which point, I can update uKasa to try the new debug feature :)
