Merlin 386.7_2 on RT-AX68U lost access to web interface
Grundor
I've been facing some random disconnects on an online game, so I decided to test merlin for a while, 2 months so far.
Tonight I got the same issue in the disconnecting, when I tried to access the web UI to my surprise the web UI was down. I do not remember the last time I accessed it, but maybe 1 or 2 days ago.
The router.asus.com was unreachable, and the 192.168.50.1 as well, I was able to access barely the https://192.168.50.1:8443 but it didn't load the interface properly after login (side menu etc).
I tried the ssh interface, connected, and tried a reboot command, but nothing happened, same for the command service restart_httpd
The only access I got atm is by ssh interface, there are any way to recover it ?
obvious question: have you tried to disconnect the power plug from the router, wait a few minutes and reconnect the power?
Yeah, so obvious that I omitted it from the original post lol.
I did the router is working, but looks like something on HTTP server crashed
it looks like i have similar problem. in logs i can see that httpd is killed after login attempt.
Dec 25 20:29:33 rc_service: watchdog 306:notify_rc start_httpd
Dec 25 20:29:33 rc_service: waitting "stop_httpd" via watchdog ...
Dec 25 20:29:34 custom_script: Running /jffs/scripts/service-event (args: start httpd)
Dec 25 20:29:35 RT-AC68U: start https:443
Dec 25 20:29:35 RT-AC68U: start httpd:80
Dec 25 20:29:37 httpd: Succeed to init SSL certificate...80
Dec 25 20:29:37 httpd: Succeed to init SSL certificate...443
Dec 25 20:50:54 kernel: httpds/22074: potentially unexpected fatal signal 11.
Dec 25 20:50:54 kernel: Pid: 22074, comm: httpds
Dec 25 20:50:54 kernel: CPU: 1 Tainted: P (2.6.36.4brcmarm #1)
Dec 25 20:50:54 kernel: PC is at 0x303430
Dec 25 20:50:54 kernel: LR is at 0x40575cf4
Dec 25 20:50:54 kernel: pc : [<00303430>] lr : [<40575cf4>] psr: 80000030
Dec 25 20:50:54 kernel: sp : bed9e0d0 ip : 40603908 fp : 2c363331
Dec 25 20:50:54 kernel: r10: 2c323331 r9 : 2c363131 r8 : 2c323131
Dec 25 20:50:54 kernel: r7 : 2c383031 r6 : 2c343031 r5 : 2c303031 r4 : 2c34362c
Dec 25 20:50:54 kernel: r3 : bed9da60 r2 : bed9da80 r1 : 00000000 r0 : ffffffff
Dec 25 20:50:54 kernel: Flags: Nzcv IRQs on FIQs on Mode USER_32 ISA Thumb Segment user
Dec 25 20:50:54 kernel: Control: 10c53c7d Table: 9974404a DAC: 00000015
Dec 25 20:51:05 watchdog: restart httpd
Dec 25 20:51:05 rc_service: watchdog 306:notify_rc stop_httpd
Dec 25 20:51:06 custom_script: Running /jffs/scripts/service-event (args: stop httpd)
Dec 25 20:51:06 rc_service: watchdog 306:notify_rc start_httpd
Dec 25 20:51:06 rc_service: waitting "stop_httpd" via watchdog ...
Dec 25 20:51:07 custom_script: Running /jffs/scripts/service-event (args: start httpd)
Dec 25 20:51:08 RT-AC68U: start https:443
Dec 25 20:51:08 RT-AC68U: start httpd:80
