Merlin Ac68 - hdd not detected
Radu Toader
I have upgraded from 380.58 to 380.62_1 and now my hdd is not detected anymore.
I have tried to revert to 380.58 but there is an error about the firmware integrity/certificate... i can only go to 380.60 but hdd is not detected in this firmware too.. i tried all versions from 380.60 > 380.62_1 and hdd is not detected.
dmesg :
Running on kernel 2.6.36.4brcmarm #2 SMP PREEMPT Wed Sep 28 20:30:17 EDT 2016 armv7l
Tuxera NTFS driver 3015.1.29.8_1 [Flags: R/W MODULE].
Tuxera HFS+ driver 3014.7.28
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci_hcd 0000:00:0b.1: EHCI Host Controller
ehci_hcd 0000:00:0b.1: new USB bus registered, assigned bus number 1
ehci_hcd 0000:00:0b.1: irq 111, io mem 0x18021000
ehci_hcd 0000:00:0b.1: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci_hcd 0000:00:0b.0: OHCI Host Controller
ohci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 2
ohci_hcd 0000:00:0b.0: irq 111, io mem 0x18022000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
fdisk -l | grep dev
Disk /dev/mtdblock0: 0 MB, 524288 bytes
Disk /dev/mtdblock0 doesn't contain a valid partition table
Disk /dev/mtdblock1: 1 MB, 1572864 bytes
Disk /dev/mtdblock1 doesn't contain a valid partition table
Disk /dev/mtdblock2: 65 MB, 65011712 bytes
Disk /dev/mtdblock2 doesn't contain a valid partition table
Disk /dev/mtdblock3: 63 MB, 63319040 bytes
Disk /dev/mtdblock3 doesn't contain a valid partition table
Disk /dev/mtdblock4: 65 MB, 65798144 bytes
Disk /dev/mtdblock4 doesn't contain a valid partition table
Disk /dev/mtdblock5: 1 MB, 1310720 bytes
Disk /dev/mtdblock5 doesn't contain a valid partition table
NOTE: resetting to factory default after flashing is
strongly recommended for the following cases:
- Updating from a firmware version that is more than 3 releases older
- Switching from a Tomato/DD-WRT/OpenWRT firmware
If you run into any issue after an upgrade and you haven't done so,
try doing a factory default reset as well.
Always read the changelog, as mandatory resets will be mentionned
there when they are necessary.
In all of these cases, do NOT load a saved copy of your settings!
This would be the same thing as NOT resetting at all, as you will
simply re-enter any invalid setting you wanted to get rid of. Make
sure to create a new backup of your settings after reconfiguring.
I did factory reset, all the times without reloading the saved conf.
I tried hdd on a pc and it worked, so its not broken:-?
I tried with usb stick and another hdd and it worked, it seems that 'sinan' usb3 enclosures doesn't work anymore, because I have 2 sinan enclosures, both not working on asus but work on pc, they used to work on asus tough... and I have tried another enclosure which works..
seems like sinan firmware is not supported anymore
