Hi guys,
First of all, I LOVE my Asus router Ac5300 but the main reason I love my router so much is because of the Merlin FW. For me being able to add a VPN per device is my main reason of using Merlin, and it works flawlessly, thank you for this. I have a few dead spots in my home so I am planning of adding an AIMesh node to my setup.
Now my main question is the following, should I keep my AC5300 as my main router and add a couple Asus RT-AX92U nodes in AiMesh mode, OR use my 5300 as an AIMesh Node and buy a RT-AX88U as my main router. Will I benefit most by the improved CPU and 4 core or would my 5300 vs RT-AX88U perform similarly.
Thank you for any advice given.
