#!/bin/sh -e
sleep 60
# Update the following variables:
USERNAME="your_username"
PASSWORD="your_password"
HOSTNAME="your_ipv4_hostname"
# Should be no need to modify anything beyond this point
/usr/sbin/curl -k --silent "https://$USERNAME:$PASSWORD@updates.dnsomatic.com/nic/update?hostname=$HOSTNAME&wildcard=NOCHG&mx=NOCHG&backmx=NOCHG&myip=" > /dev/null
if [ $? -eq 0 ]; then
/sbin/ddns_custom_updated 1
else
/sbin/ddns_custom_updated 0
fi
token="your_token"
hostname="your_ipv6_hostname"
device=br0
file=$HOME/.dynv6.addr6
[ -e $file ] && old=`cat $file`
if [ -z "$hostname" -o -z "$token" ]; then
echo "Usage: token=<your-authentication-token> [netmask=64] $0 your-name.dynv6.net [device]"
exit 1
fi
if [ -z "$netmask" ]; then
netmask=128
fi
if [ -n "$device" ]; then
device="dev $device"
fi
address=$(ip -6 addr list scope global $device | grep -v " fd" | sed -n 's/.*inet6 \([0-9a-f:]\+\).*/\1/p' | head -n 1)
if [ -e /usr/sbin/curl ]; then
bin="curl -fsS"
elif [ -e /usr/sbin/wget ]; then
bin="wget -O-"
else
echo "neither curl nor wget found"
exit 1
fi
if [ -z "$address" ]; then
echo "no IPv6 address found"
exit 1
fi
# address with netmask
current=$address/$netmask
if [ "$old" = "$current" ]; then
echo "IPv6 address unchanged"
exit
fi
# send addresses to dynv6
$bin "http://dynv6.com/api/update?hostname=$hostname&ipv6=$current&token=$token"
else
fi
$bin "http://ipv4.dynv6.com/api/update?hostname=$hostname&ipv4=auto&token=$token"
else
fi
# save current address
echo $current > $file
Welcome To SNBForums
