Merlin feature question, WiFi WAN?
schonzen
Does Merlin implement WiFi client mode routing? I'm used to this feature in DD-WRT and didn't find it with a quick search, weird feature to describe really, hope you know what I mean. To be clear this needs to be per radio
Can you be more specific? What is the exact name of the feature on DD-WRT? If you're talking about Client Mode, then that's the same as repeater mode on Merlin/ASUS.
Are you trying to bind SSID to VLAN for routing purposes?
Client mode is not supported.
