Merlin Firmware 378.55 recently installed on a RT-AC3200
guitargeek
I have a RT-AC66U here also, that when I click on Site Survey section it shows a list of clients in the area, but the RT-AC3200 shows nothing when I scan... It does act like it's scanning then stops...
Changing scan mode does not change anything....
Disable MAC filtering.
That did it Merlin, thank you!!!! I suppose they have changed the mac filtering a lot since the AC66U days, with the AC66U router, you're able to have it enabled and still do the site survey...
I was wondering, I setup my drive to have Ext4, but if I reboot the router, sometimes files disappear, but if I make the hardrive Ext2 the files remain as they should... Is there something I can do to get Ext4 to work without loosing files because of power outage or rebooting router?
I think Ext4 is not supported in the RT-AC66U. Same as the RT-N66U (same hardware).
Hey L&LD, I am having the issue on my AC3200, sorry for the confusion, I do have a AC66u as well, but yesterday I installed a AC3200 and seen EXT4 was compatible, now I am new to linux and all this stuff so I will start a new thread and see if maybe I can get a solution, would be so nice to use EXT4 as it seemed to be smoother....
