Merlin firmware for the new RT-AX86U?
It’s been fine for me for over a week. Actually faster Wi-Fi speeds on the alpha than on stock 384 which is interesting.
Got my AX86U on black friday deal yesterday.. Replaced my old AC68U. Running Merlin alpha on it now with VPN Server and VPN client. Everything rock solid so far!
Have you tried with two clients running at same time? and if you did, did it work
No. But aparently one doesn’t even work :/ i have policy rules to pipe all traffic from 3 clients through vpn and bliock if tunnel goes down. I can turn tunnel on and off and notice no difference - it’s just as if the policy rules aren’t in effect.
I have one working with policy rule when I add second one everything is messed up and I lose wan connection and internet connection icon show unconnected.
Seems all WAN routing rule is missing in routing table
@RMerlin
octopus@RT-AX86U-EA08:/tmp/home/root# routes
Table 254
default via 158.174.xxx.x dev eth0
Table 111
default via 10.128.0.1 dev tun11
Table 112
Table 113
Table 114
Table 115
@RMerlin
Table 254
Table 111
Table 112
Table 113
Table 114
Table 115
This is missing:
2020-11-30 09:42:05 NOTE: unable to redirect IPv4 default gateway -- Cannot read current default gateway from system
217.64.xxx.xx 158.174.xxx.x 255.255.255.255 UGH 0 0 0 WAN
185.86.xxx.xxx 158.174.xxx.x 255.255.255.255 UGH 0 0 0 WAN
RPDB Rules
0: from all lookup local
10001: from all to 213.136.63.73 lookup main
10101: from 192.168.12.153 lookup ovpnc1
10102: from 192.168.12.111 lookup ovpnc1
10103: from 192.168.12.157 lookup ovpnc1
10104: from 192.168.12.216 lookup ovpnc1
32766: from all lookup main
32767: from all lookup default
Table ovpnc1
10.128.0.0/22 dev tun11 proto kernel scope link src 10.128.2.128
Table ovpnc2
Table ovpnc3
Table ovpnc4
Table ovpnc5
Table main
@RMerlin
Following because I have the same issue with my VPN clients. Policies don't work at all. My whole WAN connection breaks when enabling VPN. Previously I could enter 0.0.0.0 in the destination ip but that translates to an empty string now. But that might be a functional change.
Yeah, Saw that, installed it and still facing the same issue. As soon as I enable policy rules, the VPN is unable to connect (unable to resolve purevpn's host) and my whole internet stops.
