Dec 27 22:05:41 openvpn[732]: OpenVPN 2.2.2 mipsel-linux [SSL] [LZO2] [EPOLL] built on Dec 15 2012
Dec 27 22:05:41 openvpn[732]: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Dec 27 22:05:41 openvpn[732]: Diffie-Hellman initialized with 1024 bit key
Dec 27 22:05:41 openvpn[732]: TLS-Auth MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
Dec 27 22:05:41 openvpn[732]: Socket Buffers: R=[114688->131072] S=[114688->131072]
Dec 27 22:05:41 openvpn[732]: TUN/TAP device tun21 opened
Dec 27 22:05:41 openvpn[732]: TUN/TAP TX queue length set to 100
Dec 27 22:05:41 openvpn[732]: /sbin/ifconfig tun21 10.8.0.1 pointopoint 10.8.0.2 mtu 1500
Dec 27 22:05:41 openvpn[732]: /sbin/route add -net 10.8.0.0 netmask 255.255.255.0 gw 10.8.0.2
Dec 27 22:05:41 openvpn[732]: Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
Dec 27 22:05:41 openvpn[742]: UDPv4 link local (bound): [undef]:1194
Dec 27 22:05:41 openvpn[742]: UDPv4 link remote: [undef]
Dec 27 22:05:41 openvpn[742]: MULTI: multi_init called, r=256 v=256
Dec 27 22:05:41 openvpn[742]: IFCONFIG POOL: base=10.8.0.4 size=62
Dec 27 22:05:41 openvpn[742]: Initialization Sequence Completed
Dec 27 22:06:12 openvpn[742]: event_wait : Interrupted system call (code=4)
Dec 27 22:06:12 openvpn[742]: TITLE,OpenVPN 2.2.2 mipsel-linux [SSL] [LZO2] [EPOLL] built on Dec 15 2012
Dec 27 22:06:12 openvpn[742]: TIME,Thu Dec 27 22:06:12 2012,1356642372
Dec 27 22:06:12 openvpn[742]: HEADER,CLIENT_LIST,Common Name,Real Address,Virtual Address,Bytes Received,Bytes Sent,Connected Since,Connected Since (time_t)
Dec 27 22:06:12 openvpn[742]: HEADER,ROUTING_TABLE,Virtual Address,Common Name,Real Address,Last Ref,Last Ref (time_t)
Dec 27 22:06:12 openvpn[742]: GLOBAL_STATS,Max bcast/mcast queue length,0
Dec 27 22:06:12 openvpn[742]: END
Dec 27 22:06:36 openvpn[742]: MULTI: multi_create_instance called
Dec 27 22:06:36 openvpn[742]: client ip:2053 Re-using SSL/TLS context
Dec 27 22:06:36 openvpn[742]: client ip:2053 LZO compression initialized
Dec 27 22:06:36 openvpn[742]: client ip:2053 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
Dec 27 22:06:36 openvpn[742]: client ip:2053 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
Dec 27 22:06:36 openvpn[742]: client ip:2053 TLS: Initial packet from client ip:2053, sid=dd4d8285 bfa0bb53
Dec 27 22:06:37 openvpn[742]: client ip:2053 VERIFY OK: depth=1, xxxxxxxxxxxxxxxxxx
Dec 27 22:06:37 openvpn[742]: client ip:2053 VERIFY OK: depth=0, xxxxxxxxxxxxxxxxxx
Dec 27 22:06:37 openvpn[742]: client ip:2053 TLS Auth Error: --client-config-dir authentication failed for common name 'Piasty' file='ccd/Piasty'
Dec 27 22:06:38 openvpn[742]: client ip:2053 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
Dec 27 22:06:38 openvpn[742]: client ip:2053 [Piasty] Peer Connection Initiated with client ip:2053
Dec 27 22:06:40 openvpn[742]: client ip:2053 PUSH: Received control message: 'PUSH_REQUEST'
Dec 27 22:06:40 openvpn[742]: client ip:2053 Delayed exit in 5 seconds
Dec 27 22:06:40 openvpn[742]: client ip:2053 SENT CONTROL [Piasty]: 'AUTH_FAILED' (status=1)
Dec 27 22:06:42 openvpn[742]: read UDPv4 [ECONNREFUSED]: Connection refused (code=146)
Dec 27 22:06:45 openvpn[742]: client ip:2053 SIGTERM[soft,delayed-exit] received, client-instance exiting
Dec 27 22:06:52 openvpn[742]: event_wait : Interrupted system call (code=4)
Dec 27 22:06:52 openvpn[742]: TITLE,OpenVPN 2.2.2 mipsel-linux [SSL] [LZO2] [EPOLL] built on Dec 15 2012
Dec 27 22:06:52 openvpn[742]: TIME,Thu Dec 27 22:06:52 2012,1356642412
Dec 27 22:06:52 openvpn[742]: HEADER,CLIENT_LIST,Common Name,Real Address,Virtual Address,Bytes Received,Bytes Sent,Connected Since,Connected Since (time_t)
Dec 27 22:06:52 openvpn[742]: HEADER,ROUTING_TABLE,Virtual Address,Common Name,Real Address,Last Ref,Last Ref (time_t)
Dec 27 22:06:52 openvpn[742]: GLOBAL_STATS,Max bcast/mcast queue length,0
Dec 27 22:06:52 openvpn[742]: END
