angusperde
Hello from France,
-Reset the AC66U,
- Updated to Latest Merlin 3.0.0.4_376.44
- Wan, Openpvn for Sever and Client like explained here :
https://support.hidemyass.com/hc/en-us/articles/202721136-AsusWRT-Merlin-OpenVPN-Setup-version-2-
- Start OpenVpn client 1 : VPN Status = OK for a few seconds, then Open VPN Client 1 = Stopped....
No idea why my connection has been stopped.
Also, when checking my IP, I never get the IP corresponding to the Loaded .opvn
file or to the address of the server manually entered.
Here is the Log when I Start Openvpn :
Aug 14 16:04:15 openvpn[798]: event_wait : Interrupted system call (code=4)
Aug 14 16:04:15 openvpn[798]: TITLE,OpenVPN 2.3.4 mipsel-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Aug 3 2014
Aug 14 16:04:15 openvpn[798]: TIME,Thu Aug 14 16:04:15 2014,1408021455
Aug 14 16:04:15 openvpn[798]: HEADER,CLIENT_LIST,Common Name,Real Address,Virtual Address,Bytes Received,Bytes Sent,Connected Since,Connected Since (time_t),Username
Aug 14 16:04:15 openvpn[798]: HEADER,ROUTING_TABLE,Virtual Address,Common Name,Real Address,Last Ref,Last Ref (time_t)
Aug 14 16:04:15 openvpn[798]: GLOBAL_STATS,Max bcast/mcast queue length,0
Aug 14 16:04:15 openvpn[798]: END
Aug 14 16:04:29 rc_service: httpd 334:notify_rc start_vpnclient1
Aug 14 16:04:29 openvpn[1231]: OpenVPN 2.3.4 mipsel-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Aug 3 2014
Aug 14 16:04:29 openvpn[1231]: library versions: OpenSSL 1.0.0m 5 Jun 2014, LZO 2.06
Aug 14 16:04:29 openvpn[1231]: WARNING: --ping should normally be used with --ping-restart or --ping-exit
Aug 14 16:04:29 openvpn[1231]: Socket Buffers: R=[118784->131072] S=[118784->131072]
Aug 14 16:04:29 openvpn[1235]: UDPv4 link local: [undef]
Aug 14 16:04:29 openvpn[1235]: UDPv4 link remote: [AF_INET]62.73.3.155:53
Aug 14 16:04:29 openvpn[1235]: TLS: Initial packet from [AF_INET]62.73.3.155:53, sid=01847a1f fad4f8d1
Aug 14 16:04:29 openvpn[1235]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Aug 14 16:04:33 openvpn[1235]: VERIFY OK: depth=1, C=GB, ST=London, L=London, O=Privax Ltd, OU=HMA Pro VPN, CN=hidemyass.com, name=HMA, emailAddress=info@privax.com
Aug 14 16:04:33 openvpn[1235]: VERIFY OK: nsCertType=SERVER
Aug 14 16:04:33 openvpn[1235]: VERIFY OK: depth=0, C=GB, ST=London, L=London, O=Privax Ltd, OU=HMA Pro VPN, CN=server, emailAddress=info@privax.com
Aug 14 16:04:52 openvpn[798]: event_wait : Interrupted system call (code=4)
Aug 14 16:04:52 openvpn[798]: TITLE,OpenVPN 2.3.4 mipsel-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Aug 3 2014
Aug 14 16:04:52 openvpn[798]: TIME,Thu Aug 14 16:04:52 2014,1408021492
Aug 14 16:04:52 openvpn[798]: HEADER,CLIENT_LIST,Common Name,Real Address,Virtual Address,Bytes Received,Bytes Sent,Connected Since,Connected Since (time_t),Username
Aug 14 16:04:52 openvpn[798]: HEADER,ROUTING_TABLE,Virtual Address,Common Name,Real Address,Last Ref,Last Ref (time_t)
Aug 14 16:04:52 openvpn[798]: GLOBAL_STATS,Max bcast/mcast queue length,0
Aug 14 16:04:52 openvpn[798]: END
Aug 14 16:04:53 openvpn[1235]: event_wait : Interrupted system call (code=4)
Aug 14 16:04:53 openvpn[1235]: OpenVPN STATISTICS
Aug 14 16:04:53 openvpn[1235]: Updated,Thu Aug 14 16:04:53 2014
Aug 14 16:04:53 openvpn[1235]: TUN/TAP read bytes,0
Aug 14 16:04:53 openvpn[1235]: TUN/TAP write bytes,0
Aug 14 16:04:53 openvpn[1235]: TCP/UDP read bytes,4988
Aug 14 16:04:53 openvpn[1235]: TCP/UDP write bytes,5685
Aug 14 16:04:53 openvpn[1235]: Auth read bytes,0
Aug 14 16:04:53 openvpn[1235]: END
Aug 14 16:04:59 openvpn[798]: event_wait : Interrupted system call (code=4)
Aug 14 16:04:59 openvpn[798]: TITLE,OpenVPN 2.3.4 mipsel-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Aug 3 2014
Aug 14 16:04:59 openvpn[798]: TIME,Thu Aug 14 16:04:59 2014,1408021499
Aug 14 16:04:59 openvpn[798]: HEADER,CLIENT_LIST,Common Name,Real Address,Virtual Address,Bytes Received,Bytes Sent,Connected Since,Connected Since (time_t),Username
Aug 14 16:04:59 openvpn[798]: HEADER,ROUTING_TABLE,Virtual Address,Common Name,Real Address,Last Ref,Last Ref (time_t)
Aug 14 16:04:59 openvpn[798]: GLOBAL_STATS,Max bcast/mcast queue length,0
Aug 14 16:04:59 openvpn[798]: END
Aug 14 16:05:00 openvpn[1235]: event_wait : Interrupted system call (code=4)
Aug 14 16:05:00 openvpn[1235]: OpenVPN STATISTICS
Aug 14 16:05:00 openvpn[1235]: Updated,Thu Aug 14 16:05:00 2014
Aug 14 16:05:00 openvpn[1235]: TUN/TAP read bytes,0
Aug 14 16:05:00 openvpn[1235]: TUN/TAP write bytes,0
Aug 14 16:05:00 openvpn[1235]: TCP/UDP read bytes,4988
Aug 14 16:05:00 openvpn[1235]: TCP/UDP write bytes,5761
Aug 14 16:05:00 openvpn[1235]: Auth read bytes,0
Aug 14 16:05:00 openvpn[1235]: END
Aug 14 16:05:29 openvpn[1235]: TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Aug 14 16:05:29 openvpn[1235]: TLS Error: TLS handshake failed
Aug 14 16:05:29 openvpn[1235]: SIGUSR1[soft,tls-error] received, process restarting
Aug 14 16:05:29 openvpn[1235]: Restart pause, 2 second(s)
Aug 14 16:05:31 openvpn[1235]: WARNING: --ping should normally be used with --ping-restart or --ping-exit
Aug 14 16:05:31 openvpn[1235]: Socket Buffers: R=[118784->131072] S=[118784->131072]
Aug 14 16:05:31 openvpn[1235]: UDPv4 link local: [undef]
Aug 14 16:05:31 openvpn[1235]: UDPv4 link remote: [AF_INET]62.73.3.155:53
Aug 14 16:05:31 openvpn[1235]: TLS: Initial packet from [AF_INET]62.73.3.155:53, sid=ac78783d 6b98dc59
Aug 14 16:05:36 openvpn[798]: event_wait : Interrupted system call (code=4)
Aug 14 16:05:36 openvpn[798]: TITLE,OpenVPN 2.3.4 mipsel-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Aug 3 2014
Aug 14 16:05:36 openvpn[798]: TIME,Thu Aug 14 16:05:36 2014,1408021536
Aug 14 16:05:36 openvpn[798]: HEADER,CLIENT_LIST,Common Name,Real Address,Virtual Address,Bytes Received,Bytes Sent,Connected Since,Connected Since (time_t),Username
Aug 14 16:05:36 openvpn[798]: HEADER,ROUTING_TABLE,Virtual Address,Common Name,Real Address,Last Ref,Last Ref (time_t)
Aug 14 16:05:36 openvpn[798]: GLOBAL_STATS,Max bcast/mcast queue length,0
Aug 14 16:05:36 openvpn[798]: END
Aug 14 16:05:37 openvpn[1235]: event_wait : Interrupted system call (code=4)
Aug 14 16:05:37 openvpn[1235]: OpenVPN STATISTICS
Aug 14 16:05:37 openvpn[1235]: Updated,Thu Aug 14 16:05:37 2014
Aug 14 16:05:37 openvpn[1235]: TUN/TAP read bytes,0
Aug 14 16:05:37 openvpn[1235]: TUN/TAP write bytes,0
Aug 14 16:05:37 openvpn[1235]: TCP/UDP read bytes,1222
Aug 14 16:05:37 openvpn[1235]: TCP/UDP write bytes,504
Aug 14 16:05:37 openvpn[1235]: Auth read bytes,0
Aug 14 16:05:37 openvpn[1235]: END
Aug 14 16:06:11 openvpn[1235]: VERIFY OK: depth=1, C=GB, ST=London, L=London, O=Privax Ltd, OU=HMA Pro VPN, CN=hidemyass.com, name=HMA, emailAddress=info@privax.com
Aug 14 16:06:11 openvpn[1235]: VERIFY OK: nsCertType=SERVER
Aug 14 16:06:11 openvpn[1235]: VERIFY OK: depth=0, C=GB, ST=London, L=London, O=Privax Ltd, OU=HMA Pro VPN, CN=server, emailAddress=info@privax.com
I hope someone can help me.
AL,
-Reset the AC66U,
AL,
