Hi all,
i'm new to the forum.
i've recently purchased an Asus RT-AC86U router, and i've flashed the latest release of merlin firmware.
i've configured 4 of the 5 client instances with 4 separate VPN servers (first NL, second UK etc), so, if the UK server is slow, i can turn the UK VPN off, and turn the NL VPN on. No need to have concurrent VPN running at the same time.
So far everything works.
However I'm strugling with the killswitch.
The killswitch works when i set the profile only on one of the instances (e.g. UK VPN client istance) (or at least the connection works with the profile set up, don't know how to actually test the killswitch by a failure of the VPN)
however, as soon as I enter and apply the killswitch settings on another profile (e.g. NL VPN istance) , i can nolonger access the internet. This independently if any or none of the VPN connections is active.
settings (the same for each profile):
redirect internet traffic = policy rules
block routed clients if tunnel goes down = yes
all devices: 192.168.1.0/24 -- 0.0.0.0 --> VPN
router: 192.168.1.1 -- 0.0.0.0 --> LAN
to restore internet navigation i have to set the "reduirect internet traffic" to "all" on all profiles.
is there a way to set the router so that as soon as any of the active VPN connection dorps, then the the kill switch takes over?
my expectation was to set a killswitch profile for each of the VPN istances, and the particular profile would be active, if the corresponding VPN was switched on.
thanks you.
thanks you.
