Migrate RT-AC68U to RT-AC86U
Signal range is shorter on 86U but better throughput than 68U.
Did you test both routers using the same channel? Theoretically, unii-3 would have a higher throughput than unii-1 but unii-3 would also have a shorter range.
Err... I was hoping merlin firmware can help to improve the signal range. Guest not.
The wifi code is 100% identical between my firmware and stock firmware. It won't have any impact whatsoever on wifi performance or range.
I tried the 86U for a few hours yesterday but ended up returning it. Range was the same compare to my RT-AC1900P and didn't feel it was worth $200 over my current one.
All these high-end models have pretty much reached the limit of the laws of physics in terms of coverage/performance. You will only see marginal differences between various models.
The RT-AC86U strength lies in its CPU, which gives it unmatched VPN and USB sharing performance. Also, it's aggressive pricing allows it to become a viable replacement to the RT-AC68U in that market segment (the 200$ segment).
But at this point, anyone looking to improve their wifi coverage need to look at multiple APs.
C Solved PC Download Speed 15% of Norm - Asus RT-AC86U Routers 0
