uiDivStats Missing Top Domain stats
mbze430
what does it mean if my uiDivStat is missing the top Top Block Domains and top requested domains? running merlin 386.1 beta3
How long has it been running?
Was Beta 3 a dirty upgrade? From which previous firmware version?
Does a reboot fix this issue? Are stats enabled in Diversion? Is the JFFS or the USB full, corrupted/failing?
dirty upgrade from Beta 2 which was a fresh install
REboot doesn't do anything it was working fine prior to the Beta 3. JFFS is not full nor corrupted
