I wouldn't think so, unless you *do* have success using a passive MoCA-compatible splitter in place of the powered amplifier, as I'm not aware of any amplifiers that pass MoCA signals ...without extreme loss... between the amplifier input and output ports.does this work?? (see attached image). my only issue would be getting into the cable companies enclosure ion the outside of the house and convincing my wife that its legal lol
Does such an amplifier exist? All "designed for MoCA" amps that I've seen are designed as drop amps, and have been designed to minimize loss at MoCA frequencies between the amplified output ports, and with a few "MoCA bypass" amplifiers also accommodating MoCA communication between the amplified output ports and the passive output port. Further, most "designed for MoCA" amps include a built-in MoCA filter, making such an amplifier even less likely to allow MoCA signals to pass between the input port and its outputs. (I expect such a sub-optimal setup would have better luck using a non-MoCA amp, since such an amp wouldn't include a built-in MoCA filter.)If the AMP is still used it might need to be replaced with an AMP that is engineered to pass signals in both directions if your MOCA signals need to pass through it.
In addition to the above direct-connect test detailed by @CaptainSTX, you may also want to consider a similar test using your suggested final setup for the gateway and main, bridging MoCA adapter...Start off simple and get the MOCA setup working in a test setup. Test in the room where your router is. This is where one of the MOCA adapters is going to have to be.
TEST
1. Connect adapter 1 to a LAN port on your router.
2. Take a piece of coaxial cable and connect between adapter 1 and adapter 2.
3. Connect your upstairs PC to MOCA adapter 2 using an Ethernet cable.
4. Power up both MOCA adapters and confirm that the coaxial cable is working as a LAN cable. Indicator lights on adapters will give you a clue but try connecting to web sites and run a few speed tests. If everything checks out then you are ready to go into production mode and if you experience problems in the production mode you will need to trouble shoot you coaxial network but at least you know the adapters are working.
PRODUCTION (Before starting locate any splitters in your home and verify and/or replace them with splitters that will pass in excess 1 Ghz. Normal CATV splitters installed by a MSO may be limited to 900 Mhz.)
1. Upstairs connect both your cable modem and adapter 1. Use a splitter if necessary. Plug the LAN port on the adapter into a LAN port on your router. Plug your PC back into the router.
2. Now go to any coaxial cable outlet in your home and connect adapter 2 to it and then check for LAN connectivity by plugging a PC into its LAN port. Use a splitter if necessary to connect both adapter 2 and a TV.
3. For any coaxial terminations that aren't used install terminators to reduce signal leakage.
4. Inside your demarc point which is usually outside the house install a MOCA filter before the splitter feeding your upstairs and downstairs service points on the line side/incoming side of the splitter.
This second run to the gateway location does offer another solution... MoCA active only on the "basement" coax plant, with a "PoE" MoCA filter on the input of the 4-way splitter (keeping the MoCA signals from ever getting to the amplifier). Aside from being only a slight change to your current setup, a side benefit of this solution would be experienced, eventually, if/when your cable provider begins using DOCSIS 3.1, since it isolates the incoming cable Internet signal from the MoCA signals.This bedroom has two feeds one from the outside and one from the attic.
I have yet to implement my changes because I am waiting for the tool to open my external cable enclosure.
your diagram accurately illustrates my current coax network sans MoCa connections and you modifications make sense.
Here is another diagram that might help put the Moca issue in perspective. I just posted this on another string but thought I'd include here for you. Hope it helps.
A few key things to remember is that the Moca signal must be introduced in front of the modem, splitters must be of correct frequency and bi-directional. Prior to my install my home had a signal amp on the cable signal coming into the house but I found it unnecessary in my situtation. I did require one on my OTA antenna feed. I used the Motorola Moca adapters and BAMF splitters.
Depends on the coax plant. The OP could potentially keep their modem/gateway completely isolated from MoCA signals, a plus if/when their provider begins DOCSIS 3.1 deployment.A few key things to remember is that the Moca signal must be introduced in front of the modem
Splitters should be rated through 1675 MHz, ideally, but optimal splitters for MoCA have also been designed to have reduced output port isolation at MoCA frequencies, to facilitate MoCA signal port jumping. (i.e. It's about more than just the frequency spec on the label.) That said, MoCA can work w/ standard cable-rated splitters ... but the goCoax MoCA 2.5 adapters of the OP would likely be best served by MoCA-optimal splitters, to achieve maximum throughput ... but optimizing the setup can come later. The existing splitters may support basic MoCA connectivity, and even the full range of their Internet connection.splitters must be of correct frequency
Right, understood. Which is another reason my suggested approach is beneficial... it removes the amp as a concern for your MoCA connectivity by keeping all MoCA signals downstream from the amplifier, via the "PoE" MoCA filter installed on the input of the 4-way splitter.basement AMP: as mentioned in a previous post, the cable company installed the AMP in an attempt to fix a "movie rental issue" the actual solution involved a billing error on the part of the cable company. I never removed the amp and have no way of accurately measuring cable single strength. buying a $78 single strength meter (that I will use once or twice) isn't in the budget. IMO I probably don't need it BUT I am working with long cable runs if i don't eliminate the attic run. if current coax network is left unmodified the AMP maybe necessary.
Key spec: Built-in POE filter on Input porthere is the AMP I was considering for the basement if needed (again with the elimination of the long attic run and operating under the premise that i never actually needed and AMP in the first place NO amp would be necessary)
https://www.ppc-online.com/5-and-9-port-active-return-moca-enabled-coax-amplifier-splitter
Scratch "properly" and replace it with "optimally." MoCA is designed to work with sub-optimal splitters, having built-in power amplification. It's possible that you'll get acceptable performance using your existing splitters.path of least resistance: making modifications at the external box would be much easier than messing with the splitter in the attic. IMO for this system to work properly everything that is not MoCa compliant needs to be replaced.
I believe you should be able to test this suggested setup with only a single modification to your current setup ... installing a MoCA filter on the input of the 4-way splitter pictured in post #13.
Exactly.* It's worth a shot, anyway, and closely maps to your original plans and the early bullet #3&4 suggestions by @Datalink in post #2. The extra coax run from the basement coax into the commandeered office (funny) makes it possible.so leave the AMP and add a POE filter to the input side of the four way? sounds too easy but doable.
*edit: I'm assuming that's the only change needed to your existing setup to accomplish the suggested configuration, diagrammed above, which I believe you confirmed in post #29:
Yes, the direct-connect test would be most beneficial in understanding best case as a comparison against what you find with the adapters placed at their permanent homes. (And, beyond a speed test, it would also be helpful to access the configuration UI of one of the adapters to document the MoCA statistics, again as a point of comparison.)I do need to configure the goCoax boxes and then run a performance test to get some baseline numbers
If/when the tech issues are addressed, I'd love to hear more about who gives MoCA 2.5 adapters as Christmas presents.Hello everyone: I am new to the forum and received two goCoax 2.5 boxes for Christmas
If/when the tech issues are addressed, I'd love to hear more about who gives MoCA 2.5 adapters as Christmas presents.![]()
Welcome To SNBForums
