ok thank you.moca operates at different frequencies. those are the cable modem up/down to the ISP.
You will have to install at least a pair of moca modems and check the moca modem pages. You will need to be onsite.
Yes, splitter is bi-directional. You can put the MoCA Adapter to one of the output port.On second thought I think I'm going to go with this example that you gave me. Would I be able to do it with this splitter?
Is this splitter bi-directional and allow me to put the MoCA coax into one of the output ports? View attachment 30191
I changed my mind yet again and plan on putting in this 8 port splitter.Yes, splitter is bi-directional. You can put the MoCA Adapter to one of the output port.
Yes, the sameI changed my mind yet again and plan on putting in this 8 port splitter.
I'm assuming it's bi-directional even though it doesn't say that anywhere on the product page.
Both can work for you.I'm going to with my own Cable Modem. Because they plan on still using their telephone lines, I'll need to split the incoming cable from spectrum into two.. One for the voice and modem and one for the cable/internet modem.
Will this splitter or this splitter work? If not what would you recommend? I was looking for something with the Holland brand since that's the brand that's highly recommended on here for their MoCA splitters...maybe they make something for this case scenerio.
Welcome To SNBForums
