I want to modify the CFE configuration to add Wifi area selection. On normal old type r7000, I just need to export CFE/boot section.
cat /dev/mtd0 >/tmp/cfe.bin
then i can easily change the configuration by decompressing this cfe.bin.
However for new types e.g. AX86U or AX58U, there’s no more CFe but rootfs which is about 90M size. I tried to modify it by Ultraedit directly but it seems no possible.
My question is how to modify this rootfs?
