Depends on the cost relative to buying separate parts.
Doesn't look like it is available yet anyway.
Yes. Both products are bridges and support multiple devices if you connect a switch.Is it possible to attach a hub to one end of the Netgear or Dlink? I have a HTPC and a PS3 I'd like to connect.
The more and more I look at MoCA it reminds me of a Token ring network. Would it be more accurate to call the MoCA "bridges" Media Access Units (MAUs)?
http://forums.smallnetbuilder.com/showpost.php?p=10055&postcount=16What are the steps needed to get either of these kits to work with satellite?
How concerned should I be about encryption? The Actiontec has no interface to put a password but the d-Link and Netgear do. Is this a feature that everyone should look for, or only those in certain situations, like apartment buildings?
Should be no problem interfering with OTA signals.
It works great with my home network and is faster and more reliable than wireless, but only if you use logic and not the diagrams they show you.
First of all, when I first hooked it up trying to use their diagrams, it kept disconnecting the modem from the ISP and I could never get the setup to work. Perhaps I misunderstand or misinterpreted their diagrams, but perhaps they just were too vague. Getting through to their support team is difficult at best. It is not supported at the lower levels, you have to be routed to a Senior Product Manager who specializes in this device! I never did get any support.
Here is what I finally ended up doing and it works spectacularly and reliably.
1. If you have satellite, you need to buy a Tru Spec T-3 triplexer (or equivalent). It separates out satellite, FM, and CATV frequencies. Connect the triplexer to your wall. Connect the CATV port of your triplexer to your Coax IN port on the DXN 220. If you only have a cable TV and not satellite, just hook up the DXN 220 IN to the wall using a standard CATV cable (they supply two).
2. Connect the TV OUT (ignore the TV part, it is just an out from the diplexer contained within the DXN 220) to the input of a Channel Vision C-0314 1 In 4 Out Amplified Splitter (or equivalent).
3. Connect your Cable Modem Coax connection to one of the 4 output ports on the Channel Vision.
4. Connect an Ethernet cable from the DXN 220 to one of the LAN ports on your router.
5. Connect your WAN port on the router to your Cable Modem.
6. In the other room, connect the Coax IN to the Coax connection in the wall (you can insert a splitter first if you also watch TV in the room).
7. Connect an Ethernet cable from the DXN 220 to the computer.
If the Power, LAN, Coax and 100 Mbps LED lights are on, you have a connection and there is really no need to worry about installing the software and configuring anything; it just works. If the Coax LED in front of the DXN does not glow, you do not have a good Coax connection. The only things you configure are some passwords, the frequencey (or SCAN) and Pass All if you do not need to watch TV. The defaults were fine for me.
The Channel Vision not only amplifies the signal in order to prevent yourself from being disconnected from the ISP as I was, it also allows you some flexibility in how you add devices to your network. The Channel Vision also has an internal filter to eliminate noise.
Good luck with this. I would recommend this to my clients who have problems using wireless and I know that it would work just fine.
By the way, I am using Windows 7, Build 7100 on two built-to-spec computers, one built by me and one built by AVA-Direct. (AVA's build is neater and nicer than mine.)
I am wondering if it is actually possible to send both the CATV, SAT, and MoCA signals down the same coax line utilizing the triplexer? In the example above, the SAT signals are removed by the triplexer, and the MoCA adapters are only handling CATV signals and the MoCA signals over the coax. Since this is capability is within the design intent of the technology, it works.
I am interested in sending SAT, MoCA, VHF/UHF (antenna), and CATV frequencies on the same coax line, but do not think this is possible. I searched and found the frequencies of all these items:
SAT 950 - 2200 Mhz
MoCA 875 - 1500 Mhz
VHF/UHF 54 - 450 Mhz
CATV 54 - 1002 Mhz
FM 88 - 108 Mhz
If the numbers above are correct, the SAT, CATV, and FM frequencies overlap, but a triplexer can separate them. I want to know if a triplexer can be used in combination with a MoCA adapter to send SAT, MoCA, CATV, and FM frequencies on the same coax line, even though they all overlap.
Thanks for any input.
Mark
The reason it doesn't work is that MoCA uses the same frequency band as SAT TV. Stick a SAT TV signal on the same coax and it and MoCA will collide.Anyway, the result is that it does not work. You cannot send SAT, CATV, and MoCA frequencies down the same cable with the Actiontec's; the MoCA does not work. As soon as I removed the SAT frequencies from the mix (with a diplexer), the Coax LED light up.
Welcome To SNBForums
