loveleeyoungae
My network setup is like this:
Internet
[WAN]
ISP PPPoE wireless router/modem----- for slow wireless-G devices, guests
DHCP: 192.168.1.1/255.255.255.0
No uPNP
DMZ the Asus N66U below
[LAN]
[WAN]
WAN IP: 192.168.1.2
Asus N66U with a USB hdd attached---------- main router for most devices, Smart TV, Foscam IP Camera
DHCP: 192.168.5.1/255.255.255.0
uPNP enabled
No DMZ
1. I did some searches on Google and know that DDNS configuration doesn't work behind multiple routers (a quick test on N66U confirmed that, when my No-IP host was updated with the private IP 192.168.1.2).
However, on the Foscam which has a very simple *nix-based web ui for management, there is a setting for DDNS beside the default enabled uPNP. And guess what, after I input my No-IP info in the Foscam, things worked right away! No-IP service was updated with my actual public Internet IP. And of course, I could control the Foscam and access the N66U web ui REMOTELY over the Internet and out of my home.
I guess there must be something here, because if things were that easy, advanced routers like the N66U should have already integrated the function, and people wouldn't have made so many complaints and questions on the complicated behind-multiple-routers DDNS setup. So, could anyone explain me on this situation?
2. With the temporary DDNS solution with Foscam, I setup the VPN server on the N66U with default Merlin settings (VPN Pool IP: 192.168.10.2-11).
Now when I connect to the VPN remotely, how could I access the USB hdd or other PCs in local LAN? Is the VPN IP of the N66U is 192.168.10.1? I tried to access that IP, but it didn't work.
FYI, in local LAN, from my Windows PC, I can access that USB hdd via the router local LAN IP \\192.168.5.1. Actually, I can even browse it in Network Places.
3. Without disabling DHCP or bridging any routers, how could I let the slow G devices access the devices connected to N66U, i.e. the foscam or a shared folder?
Internet
[WAN]
No uPNP
[LAN]
[WAN]
WAN IP: 192.168.1.2
uPNP enabled
No DMZ
