[ 3006.102 alpha Build(s) ] Testing available build(s)
Yeah. Scrolled by that a day. But with what I normally use only Scribe lacks an official fix via AMTM. Or at least I haven't discovered more issues yet.
Several of the scripts, particularly those who's developers (Jack Yaz for example) are no longer actively developing them, need manual update(s) by other developers who fixed them, and typically in some cases that fix isn't pulled using the AMTM update method. Generally those manual updates are mentioned in the Add-On subforum in one of the various discussions on the specific affected script. For example, the Scribe fix Martinski mentioned creating was posted to the following Scribe addon subforum discussion on August 26th.
https://www.snbforums.com/threads/s...logrotate-installer.84720/page-11#post-923834
Yeah. And some have been forked and added to AMTM with a new maintainer.
Flashed the latest 3006_102.2_alpha1-g219710951f build on my RT-BE96U and so far no issues to report. Thanks @RMerlin!
Beta build is out:
@RMerlin
We can close this :)
