Mounting issues with add-ons
Hmmm, our old nemesis is back...
Runnin 386.2 Beta 2. Addons installed are:
Unbound, scMerlin, spdMerlin, ntpMerlin, connmon and scribe/uiScribe.
After reboot last night, all addon tabs showed fine.
I added the alpha of Cake-qos 2.0 last night as well.
Did a reboot - addon tabs fine.
I needed to do a reboot this morning. Post boot, Unbound and 2 instances of scMerlin show up. It appears just the web page/tab is missing (i.e. chrony is running fine)
Here are some logs:
Mar 21 06:36:40 RT-AX88U-26A8 S77chronyd: Waiting for NTP to sync before starting...
Mar 21 06:36:48 RT-AX88U-26A8 ntpMerlin: /tmp/mnt/Entware contains Entware, starting ntpMerlin
Mar 21 06:36:55 RT-AX88U-26A8 ntpMerlin: Mounted ntpMerlin WebUI page as user6.asp
I see spdMerlin in cru and speedtests are being run/logged and spdMerlin mounting it's tab:
Mar 21 06:36:48 RT-AX88U-26A8 spdMerlin: /tmp/mnt/Entware contains Entware, starting spdMerlin
Mar 21 06:36:57 RT-AX88U-26A8 spdMerlin: Mounting spdMerlin WebUI page as user7.asp
I do see 2 WebUI mounts for scMerlin:
Mar 21 06:36:48 RT-AX88U-26A8 scMerlin: Mounting scMerlin WebUI page as user3.asp
I also see a mount of connmon WebUI (but no tab displayed):
Mar 21 06:36:48 RT-AX88U-26A8 connmon: /tmp/mnt/Entware contains Entware, starting connmon
Mar 21 06:36:54 RT-AX88U-26A8 connmon: Mounted connmon WebUI page as user5.asp
I have not done a reboot (yet). If there is any other debugging, let me know.
of my scripts, spdmerlin is the only one missing the new locking mechanism at the moment
I don't know if Unbound uses it yet, I know it was on the develop branch but I haven't followed along
I will do another reboot and see what happens.
Reboot brought them all back. Looks like (hopefully) a one off.
I forgot to mention I also have dn-vnstat added.
Could there be some cause/effect on how quickly you go to the Addon tab after a reboot? I did recall that once it rebooted this morning, I logged in immediately and went to the addon tab.
It is on the master branch and not the develop branch... just realized i missed that, Thanks.
One more datapoint. Running 386.2_beta 2 on an AX88U.
The missing tabs occurred yesterday after I had enabled Cake in the Adaptive QoS->QoS tab (new Merlin version). After I hit Apply there was a long delay, WiFi dropped, etc. It seemed close to a reboot.
After I could log in again, missing addon tabs (dn-vnstat, spdMerlin, ntpMerlin, connmon.
I did a reboot of the router (Reboot button on router home page). Addons restored.
This morning, I thought I was having a link-aggregation issue. I went to LAN->Switch Control and checked to make sure it was Enabled. It was. I hit Apply anyway.
Similar long cycle, WiFi dropped etc.
When I could log in again - missing addon tabs.
Did a manual reboot - addon tabs returned.
Not sure this helps (or if others see a similar issue). In any case, a manual reboot seems to clear things up.
