sfx2000
Part of the Furniture
I'm not so sure, because with TxBF even with MU-MIMO you are still getting the antenna gain of 1-4 dBm - those 2 streams sent out to 2 clients comes simultaneously come out (in a 4x4:4:3 radio from) THREE antenna. To be clear - 2 streams are sent out out of all THREE antenna simultaneously using pretty complicated TxBF maths, so I expect the client will be able to decode the signal nearly as well as SU-MIMO.
yes, but... an MU stream (frame set) is quasi-orthoganal by it's very nature, so a higher risk of a client having error as opposed to a standard SU frame - and one still gets the benefit of TxBF, and the additional benefit of STBC's (4*1 is a permitted config there with a four radio AP config). The TxBF gives around 1-2 dB gain on the downlink, STBC adds a couple of dB coding gain - enough so that the single client might actually be able to get one step higher MCS value...
Have to be careful on the EIRP (dBm) values, as some regulatory domains have issues (still being worked on last I checked) with regards to omni vs. TxBF and total EIRP limits...
