My experience with the RT-AC86U
No. I got this:
Not a single value here. 1 2 3 4 are the iteration numbers.
to be clear this is what I am using
Bash:
#!/bin/sh
# copy original nvram executable to /tmp
cp /bin/nvram /tmp/_nvram
# create nvram wrapper that calls original nvram executable in /tmp
cat << 'EOF' > /tmp/nvram
#!/bin/sh
#set -x # comment/uncomment to disable/enable debug mode
INTERVAL="100"
MAXCOUNT="3"
run_cmd () {
    local to
    local start
    local child
    # here as the number of tries required increases our usleep increases in case the sleep is not long enough.
    to="$1"
    to="$((to*INTERVAL))"; shift
    $@ & local child="$!" start=0
    usleep "$to"
    while { [ "$(kill -0 $child >/dev/null 2>&1; printf "%s" "$?")" = "0" ] && [ "$start" -le "$to" ]; }; do
        # to account for killing too soon, as the number of tries required increases our count requirement increases before we attempt to kill the process.
        usleep 1
        start="$((start+1))"
        if [ $start -gt $to ]; then
            kill -s 9 $child 2>/dev/null
            return 1
        fi
    done
    return 0
# make the new function accessible, on the first run we want to exit right away if successful.
i="1"
if { run_cmd "$i" /tmp/_nvram "$@"; }; then
  exit 0
fi
# here we add an interval check and allow up to 3 retries.
while [ "$i" -le "$MAXCOUNT" ]; do
  logger -t "nvram-override" "Waiting for NVRAM (retry attempt ${i}/${MAXCOUNT})"
  usleep $INTERVAL
    exit 0
  fi
  i="$((i+1))"
done
logger -t "nvram-override" "NVRAM remained locked too long; continuing anyway."
exit 1
EOF
chmod +x /tmp/nvram
# replace nvram in /usr/sbin w/ nvram wrapper in /tmp
mount -o bind /tmp/nvram /bin/nvram
I have edited it a couple of times, so many you got one that had a bad variable in it.
here is my testing script
Bash:
#!/bin/sh
trap '' HUP INT QUIT ABRT TERM
(i="0"
while true; do
  i="$(( i + 1 ))"
  for nv in 1 2 3 4 5; do
  unset "state${nv}";
  eval "state${nv}"="$(/bin/nvram get vpn_client${nv}_state)";
  done
  clear
  echo "$state1" "$state2" "$state3" "$state4" "$state5"
  echo "$i"
done) > /tmp/mynvramerror.log 2>&1 &
exit 0
I am doing tail -f /tmp/mynvramerror.log to observe the logs.
Something's unsupported here.
4
/bin/nvram: line 29: arithmetic syntax error
5
This:
Bash:
#!/bin/sh
#!/bin/sh
INTERVAL="100"
MAXCOUNT="3"
run_cmd () {
    local to
    local start
    local child
    to="$(("$1"*"$INTERVAL"))"; shift
    $@ & local child=$! start=0
    usleep $to
    while { [ "$(kill -0 $child >/dev/null 2>&1; printf "%s" "$?")" = "0" ] && [ $start -le $to ]; }; do
        usleep 1
            return 1
        fi
    done
    return 0
i=1
if { run_cmd $i /tmp/_nvram $@; }; then
  exit 0
fi
while [ $i -le $MAXCOUNT ]; do
  logger -t "nvram-override" "Waiting for NVRAM (attempt ${i}/${MAXCOUNT})"
  usleep $INTERVAL
    exit 0
  fi
  i=$((i+1))
done
exit 1
EOF
chmod +x /tmp/nvram
This:
Bash:
#!/bin/sh
#!/bin/sh
INTERVAL="100"
MAXCOUNT="3"
run_cmd () {
    local to
    local start
    local child
    usleep $to
        usleep 1
            return 1
        fi
    done
    return 0
i=1
  exit 0
fi
  usleep $INTERVAL
    exit 0
  fi
  i=$((i+1))
done
exit 1
EOF
chmod +x /tmp/nvram
You are using the wrong one..... so to speak.
mine is slightly different.
should be
to="$1"
so use the one from this post
Clocked it. 6:45 min for 3000 iterations.
No missing values.
Only 4 retries, which looks good.
Jun 17 01:38:14 nvram-override: Waiting for NVRAM (retry attempt 1/3)
Jun 17 01:40:03 nvram-override: Waiting for NVRAM (retry attempt 1/3)
Jun 17 01:43:28 nvram-override: Waiting for NVRAM (retry attempt 1/3)
Jun 17 01:43:33 nvram-override: Waiting for NVRAM (retry attempt 1/3)
Previous version took around 4:20 with many retries.
No missing values.
This might be your solution until the bug is fixed then... The interval can be fined tune to be smaller or larger. However, I suspect your number of retries per run will increase as you decrease the interval. you could even try interval 75 then 50 then 25.
It seems to me that usleep takes extra time to execute (beyond its set wait time). We can maybe try some other dummy operation instead.
When running clean nvram test loop, CPU use goes to 100% on one of the cores and high on the other. With the last override version, any core hardly touches 10%.
No missing values.
Here is a modification for testing at more than one interval.
Bash:
#!/bin/sh
#!/bin/sh
#INTERVAL="100"
MAXCOUNT="3"
run_cmd () {
    local to
    local start
    local child
    to="$1"
    usleep "$to"
        usleep 1
            return 1
        fi
    done
    return 0
for INTERVAL in 25 50 75 100; do
i="1"
  exit 0
fi
  usleep $INTERVAL
    exit 0
  fi
  i="$((i+1))"
done
done
exit 1
EOF
chmod +x /tmp/nvram
usleep appears slow to initialize.
3000 iterations, usleep 100: 6:45 min
3000 iterations, usleep 25: 6:42 min
Give or take a second.
I'd also like to have counters how many times this runs and how many errors it captures.
I had some lousy counters in my version and they were growing fast, even when I wasn't testing.
I see no difference. Funny but at 25 microsec it did only 1 retry. No empty values found. You know there's a random element to it. Sometimes it would get 2-3 fails in 3000 iterations, sometimes none.
There mere fact that usleep is in the chain, already slows things down.
I think the biggest problem with usleep is that if it fails it returns a -1 value.
Bash:
#!/bin/sh
#!/bin/sh
#INTERVAL="100"
MAXCOUNT="3"
run_cmd () {
    local to
    local start
    local child
    to="$1"
    touch /tmp/nvram
        touch /tmp/nvram
            wait $child
            return 1
        fi
    done
    return 0
i="1"
  exit 0
fi
  touch /tmp/nvram
    exit 0
  fi
  i="$((i+1))"
done
done
exit 1
EOF
chmod +x /tmp/nvram
try this mode. I removed usleep and replaced it with touch command.
This version produced 6 retries within 3:35 min. Visibly faster (2x) and no empty values.
Jun 17 02:35:24 nvram-override: Waiting for NVRAM (retry attempt 1/3)
Jun 17 02:35:25 nvram-override: Waiting for NVRAM (retry attempt 1/3)
Jun 17 02:36:29 nvram-override: Waiting for NVRAM (retry attempt 1/3)
Jun 17 02:37:35 nvram-override: Waiting for NVRAM (retry attempt 1/3)
Jun 17 02:38:07 nvram-override: Waiting for NVRAM (retry attempt 1/3)
Jun 17 02:38:40 nvram-override: Waiting for NVRAM (retry attempt 1/3)
