So I've upgraded my RT-AC88U to an 86U for a few reasons.
My network architecture at the moment is;
RT-AC88U(Merlin) = Main Router connected to VDSL Modem (WiFi disabled)
RT-AC5300(Stock) = AP/AiMesh Router
RT-AC5300(Stock) = AiMesh Node
All are connected via a Powerline ethernet backbone offering 1Gbps+ speeds between all sites.
I have one spot where 5Ghz is not as good as it could be in the Conservatory/Garden and you sometimes get booted over to 2.4Ghz, so want to add another AiMesh node there (there is already a Powerline adaptor offering hardwire services to the TV/Apple TV etc in the room).
So I'm replacing the 88U with 86U as then I get the quicker CPU for better VPN etc etc and the 88U can go back to stock and be the new AiMesh node.
It also means I can use the 86U to properly support the NTP Daemon project that I'm looking after as the original developer has drifted away from AsusWRT and asked me if I'd like to keep the project alive.
So far I've swapped the 86U in by flashing Merlin, factory reset and manually adding config back in (aside from the custom client names/DHCP reservations list which I did via an NVRAM get/set as it saved me about 2 hours doing via the GUI!).
I also swapped the USB drive with Entware on it over and updated the JFFS scripts and to my surprise it all seems to just work despite the arch64 change.
I do have a few questions/issues though.
1. Would I be better starting fresh with Entware? Are the executables working by a bit of chance or only as 32bit rather than potentially 64bit?
2. My Asterisk now gives slow/fast speech like the packets are getting held up every few seconds, even on local LAN only calls. This has always been rock solid. I just moved it to a Docker/Asterisk instance on my Synology NAS and it's perfect again (so pretty sure it's an issue with the 86U running Asterisk and not the LAN/QOS etc). Not sure if maybe related to point 1? I'm not to fussed as it's working on the NAS now anyway but just wondered if anyone had any ideas as it would save me having port forwards on my NAT to reach the NAS?
3. Reported RAM usage in the GUI is almost maxed out! The 88U (also with 512Mb on board) would run below 300Mb all the time, even with web servers and asterisk etc running on it. The output of 'free' shows that actually 110Mb of that is cached by the system so can be considered free RAM, so I'm not too concerned, but it is still using more RAM than the 88U whilst doing the exact same thing (actually doing less as Asterisk is not running now). The 88U never seemed to cache very much, but I would suggest maybe the GUI should be updated to report the +/- buffer/cache free value so as not to scare users! @RMerlin - feature request for you there
It's also worth noting the 86U reports only 440Mb of installed RAM, not sure where the other 72Mb is!? But again, is worth noting the GUI reports installed as 512Mb so not sure where it gets it's figures from (not 'free' I guess).
As always, any inputs welcomed!
Once I've run like this for a few days and got some confidence the 88U doesn't need swapping back, it'll be re-flashed and deployed as the extra AiMesh node.
